Up to 20% off select tools
Removing Numerical Keypad
Views: 14K
View statistics:
Past 24 Hours:
3
Past 7 Days:
49
Past 30 Days:
195
All Time:
14,255
Comments: 9
9 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Use this guide to cut off numerical keypad from your keyboard.
Why do this?
If you spend a lot of time typing and are experiencing pain in your right shoulder, numerical keypad may be the cause of your pain. When working with your mouse, your right hand is awkwardly positioned far right because of the useless numerical keypad.
There are myriad short keyboards on the market, but almost none retain the regular layout for insert/home/delete/arrows. This hurts me as much as my shoulder.
    1. Removing Numerical Keypad, Removing Numerical Keypad: step 1, image 1 of 1
      • You can do this with most keyboards. I had an older Dell keyboard model L100.
      Ask FixBot
    2. Removing Numerical Keypad: step 2, image 1 of 1
      • Turn the keyboard over and you will see 15 screws. Remove them.
      Ask FixBot
    3. Removing Numerical Keypad: step 3, image 1 of 1
      • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
      Ask FixBot
    4. Removing Numerical Keypad: step 4, image 1 of 1
      • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
      Ask FixBot
    5. Removing Numerical Keypad: step 5, image 1 of 1
      • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
      Ask FixBot
    6. Removing Numerical Keypad: step 6, image 1 of 1
      • Now mark the bottom part of the keyboard for another cut.
      Ask FixBot
    7. Removing Numerical Keypad: step 7, image 1 of 1
      • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
      Ask FixBot
    8. Removing Numerical Keypad: step 8, image 1 of 1
      • Screw the PCB and the metal bar back on.
      Ask FixBot
    9. Removing Numerical Keypad: step 9, image 1 of 1
      • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
      Ask FixBot
    10. Removing Numerical Keypad: step 10, image 1 of 1
      • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
      Ask FixBot
    11. Removing Numerical Keypad: step 11, image 1 of 1
      • Tape the key to the keyboad
      Ask FixBot
    12. Removing Numerical Keypad: step 12, image 1 of 1
      • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
      Ask FixBot
4 other people completed this guide.
Author
with
Stanko Vuleta
242 Reputation
1 Guide authored
9 Guide Comments
this is awful !!
Abdullah Kamran - Reply Share
This is awesome !!
What kind of saw and sawblade are you using?
Fixer - Reply Share
Manual hacksaw is probably the best choice. Any power tool is liable to burn the plastic and produce fumes which you don't want to be inhaling.
Stanko Vuleta - Reply Share
Can i do this to an aluminum extended keyboard usb apple?
appleuserfan - Reply Share
Judging by the position of the cable, the pcb is placed away from the numerical keypad, so I would guess you should be able to do it.
Past 24 Hours: 3
Past 7 Days: 49
Past 30 Days: 195
All Time: 14,255
