Up to 20% off select tools
Removing Nokia 3100b Keypad
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
85
All Time:
1,480
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The keypad inside the Nokia 3100b may eventually need replacement. This guide shows you how to access the keypad.
    1. Removing Nokia 3100b Keypad, Battery: step 1, image 1 of 1
      • Make sure your phone is turned off.
      Ask FixBot
    2. Removing Nokia 3100b Keypad: step 2, image 1 of 1
      • Press the button on the back of the phone and slide the back panel off.
      • Remove the battery by pulling it from the phone.
      Ask FixBot
    1. Removing Nokia 3100b Keypad, Removing Nokia 3100b Keypad: step 3, image 1 of 1
      • Push the black tabs down and pull the colored half of the phone from the white half.
      Ask FixBot
    2. Removing Nokia 3100b Keypad: step 4, image 1 of 1
      • The front part of the phone is now removed. Make sure nothing was damaged while removing the front cover.
      Ask FixBot
    3. Removing Nokia 3100b Keypad: step 5, image 1 of 1
      • Remove the keypad membrane by pulling it from the front cover.
      Ask FixBot
Author
with
Sterling Fuentes
139 Reputation
8 Guides authored
Cal Poly, Team 29-64, Johann Spring 2010 Member of Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 85
All Time: 1,480
