Removing Minolta X-370 Bottom Cover
    1. Removing Minolta X-370 Bottom Cover, Battery: step 1, image 1 of 2 Removing Minolta X-370 Bottom Cover, Battery: step 1, image 2 of 2
      • Flip the camera so that the bottom is facing you.
      • Take a spare coin and unscrew the battery cover off.
      Ask FixBot
    2. Removing Minolta X-370 Bottom Cover: step 2, image 1 of 1
      • Remove the batteries, making sure to note their proper alignment.
      Ask FixBot
    1. Removing Minolta X-370 Bottom Cover, Bottom Cover: step 3, image 1 of 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: step 3, image 2 of 2
      • Remove two 4.8mm screws.
      • Remove one 3.4mm screw.
      • Remove one 2.65mm screw.
      • Lift off the back cover.
      Ask FixBot
    2. Removing Minolta X-370 Bottom Cover: step 4, image 1 of 1
      • Remove three 3.5mm screws.
      • Remove two 3.8mm screws.
      • Remove one 6.35mm screw.
      • Remove one 4mm screw. Lift off the disk.
      • Remove one 5.11mm screw.
      Ask FixBot
    3. Removing Minolta X-370 Bottom Cover: step 5, image 1 of 1
      • Lift up the silver, metal piece
      • Please note that some internal pieces may come loose during this process.
      Ask FixBot
3 other people completed this guide.
Nick
525 Reputation
4 Guides authored
Cal Poly, Team 8-7, Regan Spring 2011 Member of Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Members
48 Guides authored
1 Guide Comment
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 60
All Time: 11,953
