Up to 20% off select tools
Removing JuiceBox from the wall
Views: 1.8K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
81
All Time:
1,752
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
It only takes one screw to get JuiceBox off the wall.
    1. Removing JuiceBox from the wall, Remove mounting screw: step 1, image 1 of 1
      • On most installations, the JuiceBox is held to your wall using one screw between the two cable glands. Remove this screw.
      Ask FixBot
      • After removing the mounting screw, lift JuiceBox straight up (parallel to wall) to unlatch it from the wall mounting tab. If you ever sell/give away JuiceBox, keep this wall mount tab with the box!
      • If your JuiceBox is hardwired, you would instead replace these steps with simply switching-off the breaker in preparation for the relay replacement work. To remove a hardwired unit from the wall, consult an electrician.
      Ask FixBot
Author
with
Matt Falcon
2,827 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 81
All Time: 1,752
