Removing HP Compaq dx2000MT Case Fan
    1. Removing HP Compaq dx2000MT Case Fan, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
      • Turn off your computer and remove the power cable by pulling it straight out of its socket.
      Ask FixBot
    2. Removing HP Compaq dx2000MT Case Fan: step 2, image 1 of 2 Removing HP Compaq dx2000MT Case Fan: step 2, image 2 of 2
      • Remove the two Phillips #2 screws that secure the case door to the device.
      Ask FixBot
    3. Removing HP Compaq dx2000MT Case Fan: step 3, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 3, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 3, image 3 of 3
      • Remove the side case door by pushing towards the rear of the device with your hand.
      • This may take considerable force so keep pushing!
      • Once you slide the door back, remove it by pulling it outwards from the device.
      Ask FixBot
    4. Removing HP Compaq dx2000MT Case Fan: step 4, image 1 of 1
      • Remove the two Torx T15 screws that secure the case door to the device.
      Ask FixBot
    5. Removing HP Compaq dx2000MT Case Fan: step 5, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 5, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 5, image 3 of 3
      • Once again, this may take considerable force.
      Ask FixBot
    1. Removing HP Compaq dx2000MT Case Fan, Case Fan: step 6, image 1 of 3 Removing HP Compaq dx2000MT Case Fan, Case Fan: step 6, image 2 of 3 Removing HP Compaq dx2000MT Case Fan, Case Fan: step 6, image 3 of 3
      • Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
      Ask FixBot
    2. Removing HP Compaq dx2000MT Case Fan: step 7, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 7, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 4 push fasteners from the case by:
      • Prying them outwards with a small flathead screwdriver and
      • Pulling them out with tweezers or plyers.
      Ask FixBot
    3. Removing HP Compaq dx2000MT Case Fan: step 8, image 1 of 3 Removing HP Compaq dx2000MT Case Fan: step 8, image 2 of 3 Removing HP Compaq dx2000MT Case Fan: step 8, image 3 of 3
      • Remove the fan from the case by pulling it towards the front of the device.
      Ask FixBot
3 other people completed this guide.
Logan Pace
2,414 Reputation
9 Guides authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 3,454
