Up to 20% off select tools
Removing Front Panel/ Screen Logic Board
Views: 2.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
25
All Time:
2,319
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
Removing front panel to replace main LCD or small display screen.
    1. Removing Front Panel/ Screen Logic Board, Front panel/ Screen Logic Board: step 1, image 1 of 1
      • Using the plastic opening tool, pry off the top faceplate.
      • Place the tool in the small crack that runs along the side of the phone and pry.
      Ask FixBot
    2. Removing Front Panel/ Screen Logic Board: step 2, image 1 of 1
      • Using the T6 Torx Screwdriver remove all 4 small screws.
      Ask FixBot
    3. Removing Front Panel/ Screen Logic Board: step 3, image 1 of 1
      • Remove silver plate from phone.
      Ask FixBot
    4. Removing Front Panel/ Screen Logic Board: step 4, image 1 of 1
      • Using the spudger remove the plastic camera casing
      Ask FixBot
    5. Removing Front Panel/ Screen Logic Board: step 5, image 1 of 1
      • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
      Ask FixBot
    6. Removing Front Panel/ Screen Logic Board: step 6, image 1 of 1
      • Use Spudger or hands to detach flex cable from front screen logic board
      Ask FixBot
Author
with
Cecilia
1 Reputation
3 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 2,319
