Up to 20% off select tools
Removing Dell Inspiron 1150 RAM
Views: 6.5K
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
35
All Time:
6,518
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
    1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: step 1, image 1 of 1
      • Turn the laptop so that the bottom is facing up.
      • Locate the panel that has an M on it and two air vents.
      Ask FixBot
    2. Removing Dell Inspiron 1150 RAM: step 2, image 1 of 2 Removing Dell Inspiron 1150 RAM: step 2, image 2 of 2
      • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
      • Put this screw in a bag or easily identifiable place.
      • Remove the panel.
      Ask FixBot
    3. Removing Dell Inspiron 1150 RAM: step 3, image 1 of 3 Removing Dell Inspiron 1150 RAM: step 3, image 2 of 3 Removing Dell Inspiron 1150 RAM: step 3, image 3 of 3
      • After removing the panel, you will see two memory modules.
      • Locate the four spring clips that are holding the memory modules in place.
      • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
      • Gently raise the memory module and lift it out of its socket.
      Ask FixBot
Author
with
Christopher
8 Reputation
1 Guide authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 35
All Time: 6,518
