Removing Dell Inspiron 1150 Battery Replacement
    1. Removing Dell Inspiron 1150 Battery Replacement, Battery: step 1, image 1 of 3 Removing Dell Inspiron 1150 Battery Replacement, Battery: step 1, image 2 of 3 Removing Dell Inspiron 1150 Battery Replacement, Battery: step 1, image 3 of 3
      • Place the laptop upside down on a clean, flat surface.
      • Locate the battery release button with the padlock symbol above it.
      • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
      • The battery is now released from the battery compartment.
      • Gently remove the battery from the side of the laptop.
      Ask FixBot
Finish Line
6 other people completed this guide.
Teja
98 Reputation
3 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 35
Past 30 Days: 67
All Time: 11,499
