Up to 20% off select tools
Removing DJI Phantom 2 Vision+ Case Top Shell
Views: 12K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
94
All Time:
11,954
Comments: 2
2 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Replacing the top case on your DJI Phantom 2 Vision+ drone requires removing all four propellors and threading the magnetometer cable through a small hole in the lower case. You may also need to transfer the GPS board to the replacement top case.
Note: the drone used in this guide probably looks different from yours! It's just a custom paint job, otherwise it's completely stock.
    1. Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Remove the battery: step 1, image 3 of 3
      • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
      • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
      Ask FixBot
    1. Removing DJI Phantom 2 Vision+ Case Top Shell, Propellers: step 2, image 1 of 1
      • Determine if the propellor is clockwise or counter-clockwise rotating.
      • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
      • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
      • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
      Ask FixBot
    2. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing clockwise rotating propellers: step 3, image 3 of 3
      • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
      • Remove the propellor.
      Ask FixBot
    3. Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Removing counter-clockwise rotating propellers: step 4, image 3 of 3
      • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
      Ask FixBot
    1. Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: step 5, image 1 of 2 Removing DJI Phantom 2 Vision+ Case Top Shell, Case Top Shell: step 5, image 2 of 2
      • Remove the following screws from the underside of the Phantom:
      • Twelve 2.0 mm hex bolts
      • Four Phillips #00 screws
      Ask FixBot
    2. Removing DJI Phantom 2 Vision+ Case Top Shell: step 6, image 1 of 2 Removing DJI Phantom 2 Vision+ Case Top Shell: step 6, image 2 of 2
      • Gently lift up the top shell case.
      • Do not attempt to fully remove the top shell. The GPS cable is still attached to the mainboard, avoid lifting the case too high or you may damage this connection.
      Ask FixBot
    3. Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 1 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 2 of 3 Removing DJI Phantom 2 Vision+ Case Top Shell, Unplug GPS connector and remove case: step 7, image 3 of 3
      • The GPS cable molex connector is located on the backside of the mainboard, near the battery opening.
      • Pull the GPS connector straight up out of its socket.
      • Lift the top shell case up and remove it from the body of the Phantom.
      Ask FixBot
11 other people completed this guide.
Author
with
David Hoyt
4,053 Reputation
39 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
564 Guides authored
2 Guide Comments
This guild will also largely work for the Phantom 3 (Adv./Pro) with the difference being that the phillips-head screws are T7s in the P3, and the 2mm Allen/Hex bolts are T8s.
anonymous 4102 - Reply Share
Does anyone know what the size and thread pitch for the “2.0 mm hex bolts” are? I lost the screws and need a replacement.
Matt Hirsch - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 94
All Time: 11,954
