Up to 20% off select tools
Removing Creative Zen Vision W Back Cover
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
4
Past 30 Days:
18
All Time:
1,222
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the back cover of your Removing Creative Zen Vision W.
    1. Removing Creative Zen Vision W Back Cover, Battery Removal: step 1, image 1 of 3 Removing Creative Zen Vision W Back Cover, Battery Removal: step 1, image 2 of 3 Removing Creative Zen Vision W Back Cover, Battery Removal: step 1, image 3 of 3
      • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
      Ask FixBot
    1. Removing Creative Zen Vision W Back Cover, Back Cover: step 2, image 1 of 1
      • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
      Ask FixBot
    2. Removing Creative Zen Vision W Back Cover: step 3, image 1 of 2 Removing Creative Zen Vision W Back Cover: step 3, image 2 of 2
      • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
      • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
      • Be careful, some of the screws are difficult to see and can be easily stripped.
      Ask FixBot
    3. Removing Creative Zen Vision W Back Cover: step 4, image 1 of 3 Removing Creative Zen Vision W Back Cover: step 4, image 2 of 3 Removing Creative Zen Vision W Back Cover: step 4, image 3 of 3
      • Carefully pull the back cover off of the rest of the device.
      • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
      • The USB input cover on the bottom of the device may also fall off.
      Ask FixBot
Author
with
Gabriele Pregadio
1 Reputation
2 Guides authored
Cal Poly, Team 17-2, Regan Spring 2013 Member of Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 18
All Time: 1,222
