Up to 20% off select tools
Remove the Write Protect Screw
Views: 47K
View statistics:
Past 24 Hours:
6
Past 7 Days:
50
Past 30 Days:
253
All Time:
47,147
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 9 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to take apart your 2013 Chromebook Pixel to remove the Write Protect Screw. This will allow you to install other operating systems natively.
    1. Remove the Write Protect Screw, Remove the rubber pads: step 1, image 1 of 2 Remove the Write Protect Screw, Remove the rubber pads: step 1, image 2 of 2
      • Flip your Chromebook Pixel over onto its back
      • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
      Ask FixBot
    2. Remove the Write Protect Screw, Removing the bottom panel: step 2, image 1 of 3 Remove the Write Protect Screw, Removing the bottom panel: step 2, image 2 of 3 Remove the Write Protect Screw, Removing the bottom panel: step 2, image 3 of 3
      • Using a small Philips screwdriver, remove the four screws under the pads
      • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
      • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
      Ask FixBot
    3. Remove the Write Protect Screw, Pop it open: step 3, image 1 of 2 Remove the Write Protect Screw, Pop it open: step 3, image 2 of 2
      • Gently pull up from the front of the laptop and open it up like a clamshell
      Ask FixBot
    4. Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): step 4, image 1 of 2 Remove the Write Protect Screw, Remove the write protect screw (IF APPLICABLE): step 4, image 2 of 2
      • Locate the write protect screw
      • Remove it and you can begin flashing your BIOS!
      Ask FixBot
16 other people completed this guide.
Author
with
Kevin Fessler
1,887 Reputation
4 Guides authored
4 Guide Comments
removing this will allow me to boot and install windows?
john Akday - Reply Share
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
Kevin Purdy - Reply Share
You will find more information here:
https://coolstar.org/chromebook/windows-...
Lino Bolivar - Reply Share
Acer R752TN write protect screw location?
Fredrik Løvås - Reply Share
Past 24 Hours: 6
Past 7 Days: 50
Past 30 Days: 253
All Time: 47,147
