Up to 20% off select tools
Remove the Screen
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
86
All Time:
1,129
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Better Introduction
Improve this guide by completing or revising its introduction.
Remove the Screen
Tools
    1. Remove the Screen, Remove Screws: step 1, image 1 of 3 Remove the Screen, Remove Screws: step 1, image 2 of 3 Remove the Screen, Remove Screws: step 1, image 3 of 3
      • Remove the screws from the bottom, right, and left side of camera.
      Ask FixBot
    2. Remove the Screen, Remove back: step 2, image 1 of 1
      • Remove the back of the camera, this may require force.
      Ask FixBot
    1. Remove the Screen, Remove Metal Bracket: step 3, image 1 of 1
      • Unscrew the right metal bracket of the viewing lens
      Ask FixBot
    1. Remove the Screen, Remove front of camera: step 4, image 1 of 2 Remove the Screen, Remove front of camera: step 4, image 2 of 2
      • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
      Ask FixBot
    2. Remove the Screen: step 5, image 1 of 2 Remove the Screen: step 5, image 2 of 2
      • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
      Ask FixBot
    3. Remove the Screen: step 6, image 1 of 1
      • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
      Ask FixBot
    4. Remove the Screen: step 7, image 1 of 1
      • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
      Ask FixBot
    1. Remove the Screen, Remove the Screen: step 8, image 1 of 1
      • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
      Ask FixBot
    2. Remove the Screen: step 9, image 1 of 1
      • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
      Ask FixBot
    3. Remove the Screen: step 10, image 1 of 1
      • Pull out the red wire and white wire attaching the screen to the motherboard.
      Ask FixBot
    4. Remove the Screen: step 11, image 1 of 1
      • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Melissa
270 Reputation
2 Guides authored
Ohio State, Team 1-2, Buehl Spring 2013 Member of Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 86
All Time: 1,129
