Up to 20% off select tools
Remove Stuck Disc from Samsung P241
Views: 4.9K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
131
All Time:
4,907
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Make sure you look at the Samsung P241 Troubleshooting Guide first to see if you can solve your problem without taking the DVD player apart.
If the disc tray does not come out when you press the “Eject Disc” button, listen for the sound of the motor. If it sounds like a motor is trying to open the drive but something is preventing it, the disc drive is probably jammed and you can refer to this guide to open it up and remove the jam.
If the disc drive does not open when the machine is ON and it makes no noise whatsoever, then the electronics on motherboard or in the disc drive are probably damaged. In order to fix this problem, you will have to replace the disc drive and/or motherboard. Refer to the laser repair guide to remove the disc drive, and refer to the main board repair guide to replace the motherboard.
    1. Remove Stuck Disc from Samsung P241, Top Case: step 1, image 1 of 2 Remove Stuck Disc from Samsung P241, Top Case: step 1, image 2 of 2
      • You will need to be near a power source for this guide.
      • With the back of the DVD player facing you, remove the three 1 cm black screws on the right, left, and top sides using a Phillips #1 screwdriver.
      Ask FixBot
    2. Remove Stuck Disc from Samsung P241: step 2, image 1 of 2 Remove Stuck Disc from Samsung P241: step 2, image 2 of 2
      • Pull the top cover towards you until you can lift it up and off.
      Ask FixBot
    1. Remove Stuck Disc from Samsung P241, Remove Stuck Disc from Samsung P241: step 3, image 1 of 1
      • After the top cover has been removed, locate the disc drive on the right hand side of the DVD player.
      Ask FixBot
    2. Remove Stuck Disc from Samsung P241: step 4, image 1 of 1
      • Locate the four rectangular holes in the top of the black plastic disc drive.
      Ask FixBot
    3. Remove Stuck Disc from Samsung P241: step 5, image 1 of 2 Remove Stuck Disc from Samsung P241: step 5, image 2 of 2
      • You will now pry off the black plastic cover from the disc tray. Insert a flathead screwdriver into the slot indicated and press down while at the same time pulling the screwdriver towards the middle of the device. This will pop the plastic catch out to the side.
      Ask FixBot
    4. Remove Stuck Disc from Samsung P241: step 6, image 1 of 1
      • Without removing the first screwdriver, insert a second one into the hole indicated and do the same motion.
      • You can now lift up the right side of the cover. Don't pull up too far or you could break the clasps on the left side.
      Ask FixBot
    5. Remove Stuck Disc from Samsung P241: step 7, image 1 of 1
      • Now repeat this process, unclipping the catches on the other side.
      Ask FixBot
    6. Remove Stuck Disc from Samsung P241: step 8, image 1 of 3 Remove Stuck Disc from Samsung P241: step 8, image 2 of 3 Remove Stuck Disc from Samsung P241: step 8, image 3 of 3
      • You can now pop of the black plastic cover and see the exposed disc drive. If there is anything stuck inside that is jamming the drive, you can remove it.
      Ask FixBot
Author
with
Lawrence Smith
126 Reputation
1 Guide authored
Cal Poly, Team 14-7, Forte Winter 2011 Member of Cal Poly, Team 14-7, Forte Winter 2011
CPSU-FORTE-W11S14G7
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 131
All Time: 4,907
