Remove Solid-State Drive (SSD)
    1. Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: step 1, image 1 of 2 Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: step 1, image 2 of 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Ask FixBot
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Ask FixBot
    1. Remove Solid-State Drive (SSD), Disconnect battery cable: step 3, image 1 of 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Ask FixBot
    1. Remove Solid-State Drive (SSD), Remove the system board mylar: step 4, image 1 of 2 Remove Solid-State Drive (SSD), Remove the system board mylar: step 4, image 2 of 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Ask FixBot
    1. Remove Solid-State Drive (SSD), Remove the solid-state drive (SSD) shielding: step 5, image 1 of 1
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Ask FixBot
    1. Remove Solid-State Drive (SSD), Unscrew Solid-State Drives (SSD): step 6, image 1 of 1
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      Ask FixBot
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
      Ask FixBot
johann beda
3,429 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 79
All Time: 301
