Remove Heat Sink
Featured Document
Preview of the first page of this document
Lenovo Legion 9 16irx9 Hmm
Log in to view the full document
Log In
    1. Remove Heat Sink, Remove screws from bottom of laptop.: step 1, image 1 of 2 Remove Heat Sink, Remove screws from bottom of laptop.: step 1, image 2 of 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Ask FixBot
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Ask FixBot
    1. Remove Heat Sink, Disconnect battery cable: step 3, image 1 of 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Ask FixBot
    1. Remove Heat Sink, Remove battery screws: step 4, image 1 of 1
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Ask FixBot
      • Lift out the battery.
      Ask FixBot
    1. Remove Heat Sink, Remove the system board mylar: step 6, image 1 of 2 Remove Heat Sink, Remove the system board mylar: step 6, image 2 of 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Ask FixBot
    1. Remove Heat Sink, Remove the solid-state drive (SSD) shielding: step 7, image 1 of 1
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      Ask FixBot
    1. Remove Heat Sink, Unscrew Solid-State Drives (SSD): step 8, image 1 of 1
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      Ask FixBot
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
      Ask FixBot
    1. Remove Heat Sink, Remove the Wi-Fi card: step 10, image 1 of 1
      • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
      • Remove 1 silver 2mm PH1 screw (M2 x L2).
      • Remove the Wi-Fi card by pulling it away from the slot.
      Ask FixBot
    1. Remove Heat Sink, Disconnect tape and cables: step 11, image 1 of 1
      • (1) Peel off the thermal DIMM plate tape from the system board.
      • (2-3) Lift flap and disconnect the I/O board cable from the system board.
      • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
      • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
      • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
      Ask FixBot
    2. Remove Heat Sink, Disconnect the fan cables: step 12, image 1 of 1
      • Disconnect the three fan cables from the system board by lifting away from board.
      Ask FixBot
    3. Remove Heat Sink, Remove screws and fans: step 13, image 1 of 1
      • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
      • Remove tape from fans - possibly using gentle heat
      • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
      Ask FixBot
    1. Remove Heat Sink, Disconnect cables: step 14, image 1 of 1
      • Disconnect 9 cables connected to the system board.
      Ask FixBot
    2. Remove Heat Sink, Disconnect more cables: step 15, image 1 of 1
      • Disconnect five more cables from the system board
      Ask FixBot
      • Remove 3 black 4mm PH1 screws (M2 x L4) screws
      • Remove 2 black 6mm PH1 screws (M2 x L4) screws
      • Remove the flaps of tape holding the antenna wires to the board.
      • Remove the system board module carefully.
      Ask FixBot
      • NOTE - the CPU is cooled using conductive "Liquid Metal" - if it gets on the circuit board in the wrong places it can permanently damage the board. Take extreme caution.
      • Position the board over so that the heat sink tubes are on the top
      • Loosen 6 black PH1 screws (they are captured and will not come out completely)
      • Remove 2 black 6mm screws (M2 x L6)
      • Remove 1 black 4mm screw (M2 x L4)
      • Remove the heat sink and deal with the "Liquid Metal" thermal material on the CPU.
      Ask FixBot
Attached Documents
johann beda
3,429 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 96
All Time: 347
