Up to 20% off select tools
Remove Dislodged Plug Parts
Views: 9.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
156
All Time:
9,818
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide is for either replacing the receiver jack/plug or removing parts that have broken off inside the headphones from a plug. Please read it through and make sure you are comfortable with it before attempting the teardown.
    1. Remove Dislodged Plug Parts, Remove Left Ear Cushion: step 1, image 1 of 2 Remove Dislodged Plug Parts, Remove Left Ear Cushion: step 1, image 2 of 2
      • Place the headphones down with ear cushions facing you
      • Cushions are held in by small tabs along the perimeter. Remove by hand
      Ask FixBot
    2. Remove Dislodged Plug Parts, Remove Left Driver Pad: step 2, image 1 of 2 Remove Dislodged Plug Parts, Remove Left Driver Pad: step 2, image 2 of 2
      • Pad is held in by two pieces of double-sided tape. You only need to peel back the left piece, as shown
      • Be careful to avoid tearing the pad
      Ask FixBot
    3. Remove Dislodged Plug Parts, Remove Left Backplate: step 3, image 1 of 2 Remove Dislodged Plug Parts, Remove Left Backplate: step 3, image 2 of 2
      • First, remove the two small philips screws securing the backplate to the body
      • Turn the headphones over and carefully wiggle the backplate away from the body. Use soft plastic tools if necessary to avoid scratching the plate
      Ask FixBot
    4. Remove Dislodged Plug Parts, Remove Plug Circuit Board: step 4, image 1 of 2 Remove Dislodged Plug Parts, Remove Plug Circuit Board: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two small, shorter philips screws securing the board to the body
      • The board is now held in by vinyl tape (black) and two ribbon cables
      • If you are just removing broken plug pieces, do not disconnect these ribbon cables - be careful not to damage them! Instead, simply lift the board enough to poke tweezers or similar through the plug to dislodge broken bits
      • If replacing the plug, disconnect the ribbon cables (one is soldered in place) from the circuit board and replace the board
      Ask FixBot
Reassembly is the reverse of disassembly - no surprises. Optionally, replace your ear cushions, pads, or double sided tape in the process.
6 other people completed this guide.
Author
with
Michael Pangburn
280 Reputation
1 Guide authored
4 Guide Comments
This guide was also useful to push back the pins of the headphone jack, as the plug got loose with the Gaming mic attachment.
Albert - Reply Share
Does that work for a lose 2.5 mm plug that it’s not making correct contact?
Marcos Ruiz - Reply Share
Where can i buy the spare parts ?
Term - Reply Share
Where do we even get another receiver plug?
George “calfilmmaker” - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 156
All Time: 9,818
