Remove DeLonghi ECAM series top cover
    1. Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: step 1, image 1 of 3 Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: step 1, image 2 of 3 Remove DeLonghi ECAM series top cover, Remove DeLonghi ECAM series top cover: step 1, image 3 of 3
      • Depending on the model, the steam tap/water spout must be removed, there are slight differences here.
      • Pull out the plastic clip on the steam nozzle.
      • Pull the steam nozzle out towards you.
      Ask FixBot
    2. Remove DeLonghi ECAM series top cover: step 2, image 1 of 2 Remove DeLonghi ECAM series top cover: step 2, image 2 of 2
      • Carefully pull off the steam faucet toggle. Only use a plastic tool to pry to avoid damaging the bezel.
      Ask FixBot
    3. Remove DeLonghi ECAM series top cover: step 3, image 1 of 3 Remove DeLonghi ECAM series top cover: step 3, image 2 of 3 Remove DeLonghi ECAM series top cover: step 3, image 3 of 3
      • If you haven't already done so, also detach the right-hand cover on the water tank.
      • Remove the four Phillips screws securing the top cover.
      • Lift the top cover up a bit. That might be a bit sticky.
      • Don't remove the top cover completely, some models still have cables attached to the cup warmer.
      • If there is a cup warmer, then unscrew the nut SW7 with which the two green-yellow cables are connected and loosen it. The two brown cables on the other side can stay if you just put the cover on top.
      • Place the top cover on top, or remove it entirely.
      Ask FixBot
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
343,164 Reputation
315 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 177
All Time: 3,916
