Remington MB4040 Thermal Switch Replacement
    1. Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 1 of 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 2 of 3 Remington MB4040 Thermal Switch Replacement, Remove Blade Assembly: step 1, image 3 of 3
      • Press the black button below the blade to remove the blade.
      Ask FixBot
    2. Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: step 2, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Remove Back Cover Hardware: step 2, image 2 of 2
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      Ask FixBot
    3. Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 1 of 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 2 of 3 Remington MB4040 Thermal Switch Replacement, Remove Front Cover Hardware: step 3, image 3 of 3
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      Ask FixBot
    4. Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): step 4, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Front Cover (cont.): step 4, image 2 of 2
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      Ask FixBot
    5. Remington MB4040 Thermal Switch Replacement, Blade Button Removal: step 5, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Blade Button Removal: step 5, image 2 of 2
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      Ask FixBot
    1. Remington MB4040 Thermal Switch Replacement, Remove Motherboard: step 6, image 1 of 2 Remington MB4040 Thermal Switch Replacement, Remove Motherboard: step 6, image 2 of 2
      Ask FixBot
    2. Remington MB4040 Thermal Switch Replacement, Remove Thermal Switch: step 7, image 1 of 1
      • Separate the thermal switch from the battery by using a spudger to pry it from the adhesive.
      • Use a low temperature RTV to readhere the thermal switch to the battery.
      • Remove the soldering holding the thermal switch to the motherboard.
      Ask FixBot
3 other people completed this guide.
Cameron Carnahan
1,112 Reputation
6 Guides authored
USF Tampa, Team 1-5, Blackwell Winter 2015 Member of USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 3,369
