Reliance Furnace 1910724 Filter Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
78
All Time:
749
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
  • Changing the furnace filter is a simple and important task that should be done regularly to ensure the proper functioning of your heating system. The manufacturer for Furnace is Reliance and Equipment number 1910724.
  • Materials needed:
    • New furnace filter (make sure it is the correct size for your furnace)
    • Gloves (optional)
    1. Reliance Furnace 1910724  Filter Replacement, Filter: step 1, image 1 of 1
      • Turn off your furnace to ensure your safety while changing the filter.
      Ask FixBot
    2. Reliance Furnace 1910724  Filter Replacement: step 2, image 1 of 1
      • The furnace filter usually exists in the blower compartment or in the air duct leading to the blower.
      Ask FixBot
    3. Reliance Furnace 1910724  Filter Replacement: step 3, image 1 of 1
      • Once you have found the filter placement on your model which is in lower compartment of furnace, remove the old one by sliding it out of the slot or unscrewing the cover.
      Ask FixBot
    4. Reliance Furnace 1910724  Filter Replacement: step 4, image 1 of 1
      • Dispose of the old filter in a plastic bag to prevent dust and debris from spreading.
      Ask FixBot
    5. Reliance Furnace 1910724  Filter Replacement: step 5, image 1 of 1
      • Take the new filter and slide it into the slot or attach it to the cover.
      • Make sure the arrows on the filter are pointing in the direction of the air flow. If the filter is not installed correctly, it may not function properly and could damage your furnace.
      Ask FixBot
    6. Reliance Furnace 1910724  Filter Replacement: step 6, image 1 of 1
      • Set reminder on phone or write on calendar for filter change. Furnace filters should be changed every 1-3 months, depending on usage. Set a reminder for yourself to check and change the filter regularly.
      Ask FixBot
Enjoy the clean air!
Aniqa Ashfaq
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 78
All Time: 749
