Up to 20% off select tools
Reformat SD Card
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
91
All Time:
1,719
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Reformat SD Card
Introduction
Go to step 1 ↓
The SD Card is required to save each photo before taking the next photo. This guide will show the proper steps to reformat the SD Card.
    1. Reformat SD Card, Reformat SD Card: step 1, image 1 of 2 Reformat SD Card, Reformat SD Card: step 1, image 2 of 2
      • Turn the camera on by sliding the switch from the "Off" position to the "On" position. The switch is located above the touchscreen and to the left.
      • The screen will say "Sensor cleaning" once the switch is moved to "On".
      Ask FixBot
    2. Reformat SD Card: step 2, image 1 of 1
      • Push the black button that says "Menu", located below the "ON/OFF" switch.
      Ask FixBot
    3. Reformat SD Card: step 3, image 1 of 1
      • Using the thumb pad, scroll to the 9th menu from the left.
      Ask FixBot
    4. Reformat SD Card: step 4, image 1 of 1
      • Scroll down the list using the thumb pad and select, "Format card" by pressing the center of the thumb pad labeled, "SET".
      Ask FixBot
    5. Reformat SD Card: step 5, image 1 of 2 Reformat SD Card: step 5, image 2 of 2
      • Once you select "OK", all pictures will be erased from the SD Card.
      • Press the right side of the thumb pad to move over the "Ok" button.
      • Once "OK" is highlighted, press the middle of thumb pad to initiate the formatting of the card.
      Ask FixBot
    6. Reformat SD Card: step 6, image 1 of 1
      • Wait.
      Ask FixBot
    7. Reformat SD Card: step 7, image 1 of 1
      • SD Card is now formatted.
      Ask FixBot
Author
with
John Webb
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 91
All Time: 1,719
