Redragon Sniper Pro M801-RGB Battery Replacement
  1. Redragon Sniper Pro M801-RGB Battery Replacement, Battery: step 1, image 1 of 1
    • On the underside of the mouse, use a jimmy to remove all four skates.
    • If you intend to reuse the mouse skates, be sure to avoid tearing or warping them during removal.
    Ask FixBot
  2. Redragon Sniper Pro M801-RGB Battery Replacement: step 2, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the 5 screws (one 2.5mm screw and four 9.0 mm screws).
    Ask FixBot
  3. Redragon Sniper Pro M801-RGB Battery Replacement: step 3, image 1 of 1
    • Open up the mouse without disconnecting wires.
    Ask FixBot
  4. Redragon Sniper Pro M801-RGB Battery Replacement: step 4, image 1 of 1
    • Optional: Wrap the anti-static wrist strap snugly around your wrist.
    • Attach the black grounding wire connector to one of the grounding nodes on the portable anti-static mat.
    • If you do not have the anti-static mat, attach the metal alligator clip to an external unpainted metal part like a faucet or a shelf.
    Ask FixBot
  5. Redragon Sniper Pro M801-RGB Battery Replacement: step 5, image 1 of 2 Redragon Sniper Pro M801-RGB Battery Replacement: step 5, image 2 of 2
    • Using an iFixit opening tool, wedge out the square 1000 mAH Lithium Ion battery from the bottom half and disconnect the wires connecting the battery to the rest of the mouse.
    • After connecting a new battery with the wires, use an adhesive on the new battery and stick it inside the slot.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 82
All Time: 192
