Up to 20% off select tools
Redmi Note 9 Pro Rear Glass Replacement
Views: 9.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
185
All Time:
9,717
Comments: 1
1 comment on steps.
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a damaged rear glass on your Xiaomi Redmi Note 9 Pro.
You’ll need replacement adhesive to reattach components when reassembling the device.
    1. Redmi Note 9 Pro Rear Glass Replacement, Heat the rear glass: step 1, image 1 of 1
      • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: step 2, image 1 of 3 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: step 2, image 2 of 3 Redmi Note 9 Pro Rear Glass Replacement, Insert an opening pick: step 2, image 3 of 3
      • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
      • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
      • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap you created.
      • Slide the opening pick to the bottom right corner to slice the adhesive.
      • Leave the opening pick in place to prevent the adhesive from resealing.
      Ask FixBot
    3. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: step 3, image 1 of 2 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: step 3, image 2 of 2
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: step 4, image 1 of 3 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: step 4, image 2 of 3 Redmi Note 9 Pro Rear Glass Replacement, Slice the adhesive: step 4, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
      • Insert a third opening pick at the bottom left corner of your phone.
      • Slide the opening pick along the left edge of your phone to slice the adhesive.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Redmi Note 9 Pro Rear Glass Replacement: step 5, image 1 of 2 Redmi Note 9 Pro Rear Glass Replacement: step 5, image 2 of 2
      • Insert a fourth opening pick underneath the top left corner of your phone.
      • Slide the opening pick along the top edge to slice the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Redmi Note 9 Pro Rear Glass Replacement: step 6, image 1 of 2 Redmi Note 9 Pro Rear Glass Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick underneath the top right corner.
      • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
      Ask FixBot
    7. Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: step 7, image 1 of 2 Redmi Note 9 Pro Rear Glass Replacement, Remove the rear glass: step 7, image 2 of 2
      • Remove the rear glass.
      • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
      Ask FixBot
11 other people completed this guide.
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 185
All Time: 9,717
