Redmi Note 9 Pro - Reboots, Power On flex Replacement
Video Overview
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
    1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: step 1, image 3 of 3
      • Warm up the device to soften the adhesive.
      • Use plastic tools and a little isopropyl alcohol to separate the back cover.
      Ask FixBot
    2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: step 2, image 3 of 3
      • Remove the Phillips screws that secure the motherboard cover.
      • Use a plastic opening tool to remove the cover.
      Ask FixBot
    3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: step 3, image 3 of 3
      • Lift up the flex connector to disconnect the battery.
      • Remove the main cameras.
      • Remove the SIM tray.
      Ask FixBot
    4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: step 4, image 3 of 3
      • Disconnect all flex cables:
      • Fingerprint sensor flex cable
      • Screen flex cable
      • Main flex cable
      • Coaxial antenna cable
      • Remove the Phillips screws securing the motherboard to the middle frame
      • Remove the motherboard.
      Ask FixBot
    5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: step 5, image 3 of 3
      • Remove the Fingerprint sensor.
      • Remove the volume buttons plastic cap.
      • Use isopropyl alcohol to help remove the glued down flex cable.
      Ask FixBot
    6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 1 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 2 of 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: step 6, image 3 of 3
      • Use playing cards to remove the flex cable.
      Ask FixBot
7 other people completed this guide.
ZFix
197,711 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 58
Past 30 Days: 266
All Time: 9,213
