Up to 20% off select tools
Redmi Note 4 Screen and bracket Replacement
Views: 29K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
137
All Time:
29,112
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
      • take out the sim tray
      • unscrew the two pentalobe P2 screws under the phone
      • use a suction cup and a pryer to open the phone(Very Heavy!)
      Ask FixBot
    1. Redmi Note 4 Screen and bracket Replacement: step 2, image 1 of 1
      • fingerprint cable
      • screen cable(display only)
      • power cble
      • buttons cable
      Ask FixBot
      • unplug the power cable. it should be attached just by pushing , so just lift it.
      • unplug the screen cable. they are ZIF connectors.
      • you can test the new screen here, just by plugging the new screen cable, then the power cable
      • unplug the button cable, also ZIFs.
      • remove the battery using a hard rubber spatula.(it's got handle like IPhone's, but with china quality)
      • pry from the left bottom side. NEVER from the right side, or you might damage a cable.
      • remove the remaining glue from the battery, and re-tape it inside the white lines with tapes like TESA 2mm.
      • unplug antenna wire running down right side of phone to bottom mainboard.
      Ask FixBot
    2. Redmi Note 4 Screen and bracket Replacement: step 4, image 1 of 2 Redmi Note 4 Screen and bracket Replacement: step 4, image 2 of 2
      • remove these phillips #0 screws on the upper board(forgot the number and the place, please add)
      • remove the vibration motor cover
      • remove the upper motherboard
      Ask FixBot
    3. Redmi Note 4 Screen and bracket Replacement: step 5, image 1 of 1
      • remove the phillips #0 screw from the lower casing
      • they're black, so easy to recognize
      • unplug all connectors(need photo)
      • use a hair dryer to heat the lower board(it's got glue)
      • be careful not to use force, the board is very fragile. If you feel hard to remove, heat it again.
      Ask FixBot
      • Heat the borders of your screen to loosen the glue.
      • use a suction cup to open it.
      • the cables from the screen should all be detached at this moment
      • remove all the remaining glue from the plastic bracket (I mean all)
      Ask FixBot
      • use tapes like TESA 2mm to re-glue the bracket.
      • you'll need to glue all the borders, but not around cameras, speakers, and proximity sensors.
      • Check the video I've linked to see where to glue.
      Ask FixBot
      • reverse the steps and you should be good to go!
      Ask FixBot
13 other people completed this guide.
Author
with
sub ari
470 Reputation
1 Guide authored
7 Guide Comments
Where's the video? I can't find it on this page.
Roman Belyakovsky - Reply Share
Looks like it's been removed.
http://v.youku.com/v_show/id_XMTc3NDA5ND...
Here you are.
sub ari - Reply Share
Redmi Note 4 lcd Jumper ways
Please!
KhinMaungphyo - Reply Share
Where can I find the replacement screen for this model??
The screen I ordered have the connectors the wrong place and I can't find any replacement screen with BOTH wires on the bottom …
valerie langlois - Reply Share
you could buy a new screen in taobao
牛头与画像 - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 137
All Time: 29,112
