Up to 20% off select tools
Redmi Note 4 Global Display Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
128
All Time:
8,844
Comments: 12
9 comments on steps, 3 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Screen and / or digitizer are broken but the rest of the phone is still fully functional.
    1. Redmi Note 4 Global Display Replacement, Display: step 1, image 1 of 2 Redmi Note 4 Global Display Replacement, Display: step 1, image 2 of 2
      • Use a pin to remove the SIM & SD card
      Ask FixBot
    2. Redmi Note 4 Global Display Replacement: step 2, image 1 of 3 Redmi Note 4 Global Display Replacement: step 2, image 2 of 3 Redmi Note 4 Global Display Replacement: step 2, image 3 of 3
      • With the help of a silicone spatula or similar opening tool, press gently into the separation between housing and screen
      • Gently pry the frame away from the screen .
      Ask FixBot
    3. Redmi Note 4 Global Display Replacement: step 3, image 1 of 1
      • Disconnect the rest of all the connectors. (Image shows fingerprint scanner connector already removed)
      Ask FixBot
    4. Redmi Note 4 Global Display Replacement: step 4, image 1 of 3 Redmi Note 4 Global Display Replacement: step 4, image 2 of 3 Redmi Note 4 Global Display Replacement: step 4, image 3 of 3
      • First disconnect the connector for the fingerprint scanner
      • Then carefully pry the scanner (it is adhered to the board )
      • Preheating the scanner area with a hair dryer can help
      Ask FixBot
    5. Redmi Note 4 Global Display Replacement: step 5, image 1 of 1
      • Remove all Phillips screws screws eg with a #00 Phillips driver
      Ask FixBot
    6. Redmi Note 4 Global Display Replacement: step 6, image 1 of 1
      • Remove the rest of the screws
      • Gently pry off the plastic covers
      Ask FixBot
    7. Redmi Note 4 Global Display Replacement: step 7, image 1 of 2 Redmi Note 4 Global Display Replacement: step 7, image 2 of 2
      • Remove the plastic cover from the top of the phone
      • Gentle prying may be help to loosen it.
      • Remove the screw hidden under the cover.
      Ask FixBot
    8. Redmi Note 4 Global Display Replacement: step 8, image 1 of 2 Redmi Note 4 Global Display Replacement: step 8, image 2 of 2
      • Move the plastic tab to the side to remove the main board
      Ask FixBot
    9. Redmi Note 4 Global Display Replacement: step 9, image 1 of 2 Redmi Note 4 Global Display Replacement: step 9, image 2 of 2
      • Disconnect the ribbon cable
      • Remove the screw.
      • Carefully remove the circuit board
      Ask FixBot
    10. Redmi Note 4 Global Display Replacement: step 10, image 1 of 2 Redmi Note 4 Global Display Replacement: step 10, image 2 of 2
      • Gently separate the side button bar from the frame
      Ask FixBot
    11. Redmi Note 4 Global Display Replacement: step 11, image 1 of 2 Redmi Note 4 Global Display Replacement: step 11, image 2 of 2
      • Remove the upper speaker
      • Caution: When removing the speaker, the two parts of the speaker can separate from each other. They are only held together by two very thin copper cables!
      • The best way to get to the bottom of the speaker and pry it out carefully is by using the direction of the red arrow.
      Ask FixBot
    12. Redmi Note 4 Global Display Replacement: step 12, image 1 of 2 Redmi Note 4 Global Display Replacement: step 12, image 2 of 2
      • Peel off the two battery adhesive strips to remove the battery
      • Pull as flat as possible and rather slowly. Heating the display with a hair dryer makes the whole thing a little easier.
      Ask FixBot
    13. Redmi Note 4 Global Display Replacement: step 13, image 1 of 1
      • Disconnect the ribbon cable for the charging board. Keep it safe for later reuse.
      Ask FixBot
    14. Redmi Note 4 Global Display Replacement: step 14, image 1 of 2 Redmi Note 4 Global Display Replacement: step 14, image 2 of 2
      • Depending on the completeness of the replacement part, the LED lighting may also be removed
      • T o remove it, gently pry with some pointed tweezers or similar tool
      Ask FixBot
    15. Redmi Note 4 Global Display Replacement, First Test: step 15, image 1 of 2 Redmi Note 4 Global Display Replacement, First Test: step 15, image 2 of 2
      • For testing purposes, the button bar, the screen and the battery can be connected.
      • Attention! When doing so, there is an increased risk of damaging the connections or the battery. Be very careful!
      • A long press on the bottom button should start the phone
      Ask FixBot
    16. Redmi Note 4 Global Display Replacement: step 16, image 1 of 1
      • Insert the upper speaker and press it into the end position
      Ask FixBot
    17. Redmi Note 4 Global Display Replacement: step 17, image 1 of 1
      • If previously removed, insert the LED bar (red circle)
      • Insert the charging board into proper position and tighten (blue circle)
      Ask FixBot
    18. Redmi Note 4 Global Display Replacement: step 18, image 1 of 1
      • Remove the blue protective strip from the corresponding adhesive surface. Insert the ribbon cable into the power supply
      • Press the cable flat onto the adhesive area
      • Ensure everything is properly aligned
      Ask FixBot
    19. Redmi Note 4 Global Display Replacement: step 19, image 1 of 1
      • Install the lower plastic cover and screw it in place
      Ask FixBot
    20. Redmi Note 4 Global Display Replacement: step 20, image 1 of 3 Redmi Note 4 Global Display Replacement: step 20, image 2 of 3 Redmi Note 4 Global Display Replacement: step 20, image 3 of 3
      • Insert the motherboard
      • Use the metal pin and the plastic hook to check proper alignment.
      Ask FixBot
    21. Redmi Note 4 Global Display Replacement: step 21, image 1 of 1
      • Reconnect all connectors
      Ask FixBot
    22. Redmi Note 4 Global Display Replacement, Replacing the battery: step 22, image 1 of 2 Redmi Note 4 Global Display Replacement, Replacing the battery: step 22, image 2 of 2
      • Remove the cover from the two adhesive strips for the battery
      • Insert the battery and reconnect it.
      Ask FixBot
    23. Redmi Note 4 Global Display Replacement: step 23, image 1 of 1
      • Press the fingerprint scanner back into its position.
      • Press the display back into the housing. Done!
      Ask FixBot
Repeat the steps in reverse order to reassemble your device.
5 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Frederic
487 Reputation
1 Guide authored
3 Guide Comments
There are major steps missing between step 14 and step 15. This is not a complete guide on screen replacement.
Don - Reply Share
Hi Don, which steps are you missing between 14 and 15 ? Once all parts are removed from the old display one can try the test fit on the new display.
Frederic - Reply Share
Watch and pray ,global warming.
Jerry Scott - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 128
All Time: 8,844
