RedOctane X-Plorer Whammy Bar Sensor Replacement
  1. RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Whammy Bar Sensor Replacement, Rear Case: step 1, image 2 of 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    Ask FixBot
  2. RedOctane X-Plorer Whammy Bar Sensor Replacement: step 2, image 1 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: step 2, image 2 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: step 2, image 3 of 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    Ask FixBot
  3. RedOctane X-Plorer Whammy Bar Sensor Replacement: step 3, image 1 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: step 3, image 2 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement: step 3, image 3 of 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    Ask FixBot
  4. RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: step 4, image 1 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: step 4, image 2 of 3 RedOctane X-Plorer Whammy Bar Sensor Replacement, Whammy Bar Sensor: step 4, image 3 of 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
    Ask FixBot
  5. RedOctane X-Plorer Whammy Bar Sensor Replacement: step 5, image 1 of 2 RedOctane X-Plorer Whammy Bar Sensor Replacement: step 5, image 2 of 2
    • Using one hand, remove the whammy bar and its attached components from the case.
    Ask FixBot
  6. RedOctane X-Plorer Whammy Bar Sensor Replacement: step 6, image 1 of 1
    • Using two hands, remove the whammy bar sensor.
    Ask FixBot
Riley
703 Reputation
7 Guides authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
9 Guides authored
1 Guide Comment
Hi, can you please tell me what part I need to replace the sensor? Thanks!
Brian Kohrman - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 35
All Time: 1,538
