RedOctane X-Plorer Strum Bar Sensor Board Replacement
    1. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Rear Case: step 1, image 2 of 2
      • Remove the strap by pulling it off of the mounts located on the body and neck.
      Ask FixBot
    2. RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 2, image 1 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 2, image 2 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 2, image 3 of 3
      • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
      • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
      • These screws can also be Torx on some models.
      • Pull off the rear case.
      Ask FixBot
    3. RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 3, image 1 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 3, image 2 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement: step 3, image 3 of 3
      • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
      • Pull off the top shell of the neck to expose the internal features.
      Ask FixBot
    1. RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: step 4, image 1 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: step 4, image 2 of 3 RedOctane X-Plorer Strum Bar Sensor Board Replacement, Strum Bar Sensor Board: step 4, image 3 of 3
      • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
      • Lift up on the strum bar sensor board to remove it from the case.
      Ask FixBot
Riley
703 Reputation
7 Guides authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 50
All Time: 3,629
