RedOctane X-Plorer Pedal Input Replacement
  1. RedOctane X-Plorer Pedal Input Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Pedal Input Replacement, Rear Case: step 1, image 2 of 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
    Ask FixBot
  2. RedOctane X-Plorer Pedal Input Replacement: step 2, image 1 of 3 RedOctane X-Plorer Pedal Input Replacement: step 2, image 2 of 3 RedOctane X-Plorer Pedal Input Replacement: step 2, image 3 of 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
    Ask FixBot
  3. RedOctane X-Plorer Pedal Input Replacement: step 3, image 1 of 3 RedOctane X-Plorer Pedal Input Replacement: step 3, image 2 of 3 RedOctane X-Plorer Pedal Input Replacement: step 3, image 3 of 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
    Ask FixBot
  4. RedOctane X-Plorer Pedal Input Replacement, RJ-14 Connector: step 4, image 1 of 3 RedOctane X-Plorer Pedal Input Replacement, RJ-14 Connector: step 4, image 2 of 3 RedOctane X-Plorer Pedal Input Replacement, RJ-14 Connector: step 4, image 3 of 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
    Ask FixBot
Riley
703 Reputation
7 Guides authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,336
