Up to 20% off select tools
RedOctane X-Plorer Front Case Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
64
All Time:
1,500
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The front case of the guitar is primarily decorative, but removing it is vital to access the internal components of the guitar. This guide will show you how to replace the front cover of the guitar.
    1. RedOctane X-Plorer Front Case Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Front Case Replacement, Rear Case: step 1, image 2 of 2
      • Remove the strap by pulling it off of the mounts located on the body and neck.
      Ask FixBot
    2. RedOctane X-Plorer Front Case Replacement: step 2, image 1 of 3 RedOctane X-Plorer Front Case Replacement: step 2, image 2 of 3 RedOctane X-Plorer Front Case Replacement: step 2, image 3 of 3
      • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
      • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
      • These screws can also be Torx on some models.
      • Pull off the rear case.
      Ask FixBot
    3. RedOctane X-Plorer Front Case Replacement: step 3, image 1 of 3 RedOctane X-Plorer Front Case Replacement: step 3, image 2 of 3 RedOctane X-Plorer Front Case Replacement: step 3, image 3 of 3
      • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
      • Pull off the top shell of the neck to expose the internal features.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Auxiliary Port: step 4, image 1 of 3 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: step 4, image 2 of 3 RedOctane X-Plorer Front Case Replacement, Auxiliary Port: step 4, image 3 of 3
      • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
      • Gently lift up on the auxiliary port to remove it from the case.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: step 5, image 1 of 3 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: step 5, image 2 of 3 RedOctane X-Plorer Front Case Replacement, RJ-14 Connector: step 5, image 3 of 3
      • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
      • Lift the RJ-14 connector to remove it from the case.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Keys: step 6, image 1 of 3 RedOctane X-Plorer Front Case Replacement, Keys: step 6, image 2 of 3 RedOctane X-Plorer Front Case Replacement, Keys: step 6, image 3 of 3
      • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
      • Lift up on the key sensor board to remove it from the guitar neck.
      • When using the screwdriver, make sure to avoid puncturing the wires.
      Ask FixBot
    2. RedOctane X-Plorer Front Case Replacement: step 7, image 1 of 1
      • Using your fingers, remove the rubber pad to expose the colored keys.
      Ask FixBot
    3. RedOctane X-Plorer Front Case Replacement: step 8, image 1 of 2 RedOctane X-Plorer Front Case Replacement: step 8, image 2 of 2
      • Reach one finger under the guitar to push the key out of the casing.
      • Repeat this step for the four remaining keys.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: step 9, image 1 of 3 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: step 9, image 2 of 3 RedOctane X-Plorer Front Case Replacement, Strum Bar Sensor Board: step 9, image 3 of 3
      • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
      • Lift up on the strum bar sensor board to remove it from the case.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: step 10, image 1 of 3 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: step 10, image 2 of 3 RedOctane X-Plorer Front Case Replacement, Whammy Bar Sensor: step 10, image 3 of 3
      • Remove the two 7mm Phillips #0 screws.
      • Using your fingers, remove the black wire retainer.
      Ask FixBot
    2. RedOctane X-Plorer Front Case Replacement: step 11, image 1 of 2 RedOctane X-Plorer Front Case Replacement: step 11, image 2 of 2
      • Using one hand, remove the whammy bar and its attached components from the case.
      Ask FixBot
    3. RedOctane X-Plorer Front Case Replacement: step 12, image 1 of 1
      • Using two hands, remove the whammy bar sensor.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Motherboard: step 13, image 1 of 3 RedOctane X-Plorer Front Case Replacement, Motherboard: step 13, image 2 of 3 RedOctane X-Plorer Front Case Replacement, Motherboard: step 13, image 3 of 3
      • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
      • Lift the motherboard to remove it from the case.
      Ask FixBot
    1. RedOctane X-Plorer Front Case Replacement, Front Case: step 14, image 1 of 2 RedOctane X-Plorer Front Case Replacement, Front Case: step 14, image 2 of 2
      • Remove the four 12mm Phillips #1 that connect the body to the neck using a screwdriver.
      Ask FixBot
    2. RedOctane X-Plorer Front Case Replacement: step 15, image 1 of 1
      • Remove the neck panel from the front body panel.
      Ask FixBot
Author
with
Riley
703 Reputation
7 Guides authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 64
All Time: 1,500
