Up to 20% off select tools
Recirculating Chiller Temperature Control for Precise Laboratory Cooling
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
36
All Time:
44
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
The Labotronics guide, “Recirculating Chiller for Laboratory Cooling: The Essential Guide to Precise Temperature Control,” explains how recirculating chillers support laboratory equipment by maintaining controlled cooling conditions during experiments and routine operations.
A recirculating chiller removes heat from connected equipment and circulates cooled fluid through a closed loop. This helps regulate operating temperatures and supports applications that require consistent cooling, including analytical instruments, laboratory reactors, lasers, and other temperature-sensitive equipment.
The article explores the role of temperature control in laboratory workflows and highlights key factors involved in selecting a suitable chiller. Cooling capacity, temperature range, flow rate, pressure, reservoir volume, and fluid compatibility all influence system suitability for a particular application.
Proper installation and routine maintenance help support chiller performance. Laboratories should check coolant levels, inspect hoses and connections, clean filters where applicable, and follow manufacturer recommendations for coolant selection and servicing.
Want to improve temperature control in your laboratory? Read the complete Labotronics guide to explore recirculating chiller applications, operating principles, and key selection factors.
Ruth Curry
31 Reputation
80 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 36
All Time: 44
