Recalibrating the center of Thrustmaster T300
  1. Recalibrating the center of Thrustmaster T300, Setting up the steering wheel: step 1, image 1 of 1
    • Connect and start the steering wheel.
    • If you are on a PC, set the rotation angle to 1080° from the Thrustmaster control panel.
    • If you are on a console, manually set the rotation angle to 1080°.
    • To do this, press the “Right D-PAD + MODE” buttons simultaneously to increase the angle of rotation. The base LED should flash 5 times.
    Ask FixBot
  2. Recalibrating the center of Thrustmaster T300, Recalibrating the center: step 2, image 1 of 3 Recalibrating the center of Thrustmaster T300, Recalibrating the center: step 2, image 2 of 3 Recalibrating the center of Thrustmaster T300, Recalibrating the center: step 2, image 3 of 3
    • Turn the steering wheel all the way to the left, as far as it will go.
    • Turn the steering wheel all the way to the right, as far as it will go.
    • Recenter your wheel.
    • Press the buttons to recenter the steering wheel. These buttons vary depending on what model you have, but you can find out which to use here.
    Ask FixBot
    • Once the central value has been reset, the LED on your base should then briefly change color, validating the procedure.
    • You can then verify whether the wheel is steering properly using the Thrustmaster Control Panel.
    Ask FixBot
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Kaysleam
2,090 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 108
All Time: 2,058
