Reattaching the GEN 2 Wheelchair Foot Support
    1. Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: step 1, image 1 of 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: step 1, image 2 of 3 Reattaching the GEN 2 Wheelchair Foot Support, Foot Support: step 1, image 3 of 3
      • Slide the footrest sockets down as shown and use a 10 mm wrench to tighten the bolts at the desired height.
      Ask FixBot
    2. Reattaching the GEN 2 Wheelchair Foot Support: step 2, image 1 of 1
      • Screw in the bolt to the top socket to secure the height of the footrest.
      Ask FixBot
    3. Reattaching the GEN 2 Wheelchair Foot Support: step 3, image 1 of 2 Reattaching the GEN 2 Wheelchair Foot Support: step 3, image 2 of 2
      • Screw in the bolt attaching the footrest to the frame.
      • Screw in the lower bolt to the footrest.
      Ask FixBot
Check that the footrest is at the desired height. If the footrest is still uncomfortable start the guide over again from step 1 using a different height to tighten bolts.
Kali Slaughter
257 Reputation
5 Guides authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
71 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 51
All Time: 1,212
