Up to 20% off select tools
Rear Case Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
83
All Time:
1,451
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide for accessing the internal workings of the camera. Before following these instructions make sure the proper replacement parts are available.
    1. Rear Case Replacement, Rear Case: step 1, image 1 of 3 Rear Case Replacement, Rear Case: step 1, image 2 of 3 Rear Case Replacement, Rear Case: step 1, image 3 of 3
      • Remove the seven highlighted screws shown here.
      • Screws are teeny tiny, don't lose them!
      Ask FixBot
    2. Rear Case Replacement: step 2, image 1 of 2 Rear Case Replacement: step 2, image 2 of 2
      • Remove this final screw from the memory card compartment.
      • Remove the chassis by pulling the back cover away from the camera.
      • Be careful not to damage any of the delicate ribbon cables when removing the chassis.
      Ask FixBot
    3. Rear Case Replacement: step 3, image 1 of 2 Rear Case Replacement: step 3, image 2 of 2
      • Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Leonard Holloman
662 Reputation
4 Guides authored
USF Tampa, Team 4-4, Meier Fall 2015 Member of USF Tampa, Team 4-4, Meier Fall 2015
USFT-MEIER-F15S4G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 83
All Time: 1,451
