Realigning 12-Inch Bionaire Fan Metal Coil
Views: 4.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
120
All Time:
4,741
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Annoyed by the fact that your fan won't stay in a desired, fixed position? This fast fix guide will help correct that problem in no time!
Tools
    1. Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: step 1, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil, Realigning 12-Inch Bionaire Fan Metal Coil: step 1, image 2 of 2
      • Unlock all of the tabs holding the fan cage together.
      • Carefully pull off the cage.
      Ask FixBot
    2. Realigning 12-Inch Bionaire Fan Metal Coil: step 2, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 2, image 2 of 2
      • Using a Phillips #2 screwdriver, untighten the 1/4'' screw that is located underneath the fan blade.
      • Blade may be sharp so watch out!
      • Cautiously remove the blade from the hinge.
      • Put the screws in a cup so you don't lose them!
      Ask FixBot
    3. Realigning 12-Inch Bionaire Fan Metal Coil: step 3, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 3, image 2 of 2
      • Rotate the black cap counter-clockwise to disconnect it from the back fan cage.
      • Pull off the back cage from the engine holder.
      Ask FixBot
    4. Realigning 12-Inch Bionaire Fan Metal Coil: step 4, image 1 of 1
      • Working with the Phillips #2 screwdriver, loosen the 1/4'' center hinge screw from the metal base.
      Ask FixBot
    5. Realigning 12-Inch Bionaire Fan Metal Coil: step 5, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 5, image 2 of 2
      • Using the Phillips #2 screwdriver, separate the wire holder from the back of black cover by removing the two 1/8'' screws.
      Ask FixBot
    6. Realigning 12-Inch Bionaire Fan Metal Coil: step 6, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 6, image 2 of 2
      • Pull of the black knob by rotating the knob counter-clockwise.
      • Pull down the black cover all the way.
      • The coil may pop out after removing the cover.
      Ask FixBot
    7. Realigning 12-Inch Bionaire Fan Metal Coil: step 7, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 7, image 2 of 2
      • Take out the gold metal spring.
      • Realign the metal coil into designated space.
      • Push the coil in with some force so it rests perfectly in the space.
      • To make placing the coil back in more easier, use the screwdriver!
      Ask FixBot
    8. Realigning 12-Inch Bionaire Fan Metal Coil: step 8, image 1 of 2 Realigning 12-Inch Bionaire Fan Metal Coil: step 8, image 2 of 2
      • Align the end of the metal coil into the same hole the black wire comes out of in the black cover from step 6.
      • This can be a frustrating step. Be patient!
      Ask FixBot
3 other people completed this guide.
Hemish Patel
231 Reputation
1 Guide authored
Cal Poly, Team 10-3, Green Fall 2015 Member of Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 Members
48 Guides authored
1 Guide Comment
I have a fan It hum I have to spin the blade for it to start spin
Chris - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 120
All Time: 4,741
