RazorX DLX Electric Skateboard Power Button Replacement
  1. RazorX DLX Electric Skateboard Power Button Replacement, Battery: step 1, image 1 of 3 RazorX DLX Electric Skateboard Power Button Replacement, Battery: step 1, image 2 of 3 RazorX DLX Electric Skateboard Power Button Replacement, Battery: step 1, image 3 of 3
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
    Ask FixBot
  2. RazorX DLX Electric Skateboard Power Button Replacement: step 2, image 1 of 1
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
    Ask FixBot
  3. RazorX DLX Electric Skateboard Power Button Replacement, Control Module: step 3, image 1 of 3 RazorX DLX Electric Skateboard Power Button Replacement, Control Module: step 3, image 2 of 3 RazorX DLX Electric Skateboard Power Button Replacement, Control Module: step 3, image 3 of 3
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
    Ask FixBot
  4. RazorX DLX Electric Skateboard Power Button Replacement: step 4, image 1 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 4, image 2 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 4, image 3 of 3
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
    Ask FixBot
  5. RazorX DLX Electric Skateboard Power Button Replacement: step 5, image 1 of 1
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
    Ask FixBot
  6. RazorX DLX Electric Skateboard Power Button Replacement: step 6, image 1 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 6, image 2 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 6, image 3 of 3
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
    Ask FixBot
  7. RazorX DLX Electric Skateboard Power Button Replacement: step 7, image 1 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 7, image 2 of 3 RazorX DLX Electric Skateboard Power Button Replacement: step 7, image 3 of 3
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
    Ask FixBot
  8. RazorX DLX Electric Skateboard Power Button Replacement: step 8, image 1 of 2 RazorX DLX Electric Skateboard Power Button Replacement: step 8, image 2 of 2
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
    Ask FixBot
  9. RazorX DLX Electric Skateboard Power Button Replacement: step 9, image 1 of 1
    • Remove the Control Module by lifting it out of the plastic housing.
    Ask FixBot
  10. RazorX DLX Electric Skateboard Power Button Replacement, Power Button: step 10, image 1 of 2 RazorX DLX Electric Skateboard Power Button Replacement, Power Button: step 10, image 2 of 2
    • Disconnect the power button from the control module.
    • Pinch the two plastic tabs to remove the power button from the plastic body.
    Ask FixBot
Emmett Normand
974 Reputation
8 Guides authored
Cuesta, Team 20-4, Krynen Fall 2024 Member of Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 239
