Razor Hovertrax 2.0 Wheel Hub Replacement
  1. Razor Hovertrax 2.0 Wheel Hub Replacement, Battery: step 1, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement, Battery: step 1, image 2 of 2
    • Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
  2. Razor Hovertrax 2.0 Wheel Hub Replacement: step 2, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement: step 2, image 2 of 2
    • To remove the led connector from the board, press the clip in with your fingers and gently pull up.
    • The connector you are removing is black and has two pins.
    • If it does not want to come out, gently wiggle the connector side to side while pulling up.
  3. Razor Hovertrax 2.0 Wheel Hub Replacement: step 3, image 1 of 1
    • Disconnect the battery connector by grabbing the black side with one hand and the yellow side with the other hand and gently pull apart. (Try not to pull on the wires, it could damage them)
    • If you are replacing other parts, leave the battery disconnected until the end.
  4. Razor Hovertrax 2.0 Wheel Hub Replacement: step 4, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement: step 4, image 2 of 2
    • Remove the two 17.2 mm hex head bolts using the 4 mm hex screwdriver that secures the battery in place.
  5. Razor Hovertrax 2.0 Wheel Hub Replacement: step 5, image 1 of 1
    • The battery should be able to be lifted up out of the device now.
  6. Razor Hovertrax 2.0 Wheel Hub Replacement, Wheel Hub: step 6, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement, Wheel Hub: step 6, image 2 of 2
    • After disconnecting the battery, depending on which wheel hub needs replacing, you may need to take off the cover for the other side of the hoverboard. Using the #2 Phillips screwdriver, remove the eight 18.5 mm screws that are circled)
    • Be careful when removing the cover, there will be wires connected to the components in the cover.
  7. Razor Hovertrax 2.0 Wheel Hub Replacement: step 7, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement: step 7, image 2 of 2
    • Once all of the screws are removed, gently lift the cover up and angle it up.
  8. Razor Hovertrax 2.0 Wheel Hub Replacement: step 8, image 1 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 8, image 2 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 8, image 3 of 3
    • There are 2 wires that have to be disconnected before we can set the cover aside
    • To remove the connectors, press and hold the clip with your fingers and gently pull up (if it is not coming out, gently wiggle the connector side to side while pulling up)
    • Set the cover aside
  9. Razor Hovertrax 2.0 Wheel Hub Replacement: step 9, image 1 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 9, image 2 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 9, image 3 of 3
    • 4 connections must be removed before we can take out the motherboard covering the screws holding in the wheel hub.
    • To remove the connectors, press and hold the clip/connector and gently pull up (if the connector does not want to come out, gently wiggle it side to side while pulling up)
  10. Razor Hovertrax 2.0 Wheel Hub Replacement: step 10, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement: step 10, image 2 of 2
    • Using the #2 Phillips screwdriver, remove these four 11.6 mm screws
    • The measurement of the screw is the average length of all screws!
    • When lifting the board up, try not to touch the bottom, there is a capacitor that may be holding a charge.
    • Lift the board up by grabbing it by the edges and set it aside.
  11. Razor Hovertrax 2.0 Wheel Hub Replacement: step 11, image 1 of 2 Razor Hovertrax 2.0 Wheel Hub Replacement: step 11, image 2 of 2
    • Using the 5 mm hex screwdriver, remove the 4 (22 mm) hex bolts (no need to be gentle here, they are tight and need some force to be removed)
  12. Razor Hovertrax 2.0 Wheel Hub Replacement: step 12, image 1 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 12, image 2 of 3 Razor Hovertrax 2.0 Wheel Hub Replacement: step 12, image 3 of 3
    • Use an 10 mm socket or wrench to remove the 2 bolts (13.6 mm).
    • After all of the bolts are removed, take the wheel hub out and set the hoverboard aside.
    • Now the wires must be gently pulled through the bracket so the wheel hub and bracket are separate.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 19
All Time: 502
