Razor AW Kick Wheelie Bar Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
117
All Time:
867
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If the wheelie bar on your Razor AW Kick Scooter is worn out or it's affecting your performance, follow this guide to replace it or remove it altogether.
A wheelie bar is a scooter part that can be used for performing tricks or as a footrest stand when using the scooter for transportation.
Tools
    1. Razor AW Kick Wheelie Bar Replacement, Wheelie Bar: step 1, image 1 of 3 Razor AW Kick Wheelie Bar Replacement, Wheelie Bar: step 1, image 2 of 3 Razor AW Kick Wheelie Bar Replacement, Wheelie Bar: step 1, image 3 of 3
      • Place the scooter on its side and on the ground.
      • Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
      • Remove the screw using the 5 mm Hex Security key.
      • Remove the screw from the scooter frame.
      Ask FixBot
    2. Razor AW Kick Wheelie Bar Replacement: step 2, image 1 of 3 Razor AW Kick Wheelie Bar Replacement: step 2, image 2 of 3 Razor AW Kick Wheelie Bar Replacement: step 2, image 3 of 3
      • Remove the wheel from the scooter slowly.
      • Remove the black wheel holders from the scooter frame.
      Ask FixBot
    3. Razor AW Kick Wheelie Bar Replacement: step 3, image 1 of 2 Razor AW Kick Wheelie Bar Replacement: step 3, image 2 of 2
      • Remove the wheelie bar from the scooter frame.
      Ask FixBot
To reassemble your device, follow these instructions in revise order.
Alexander Vazquez
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 117
All Time: 867
