Razer Wolverine V3 Pro Battery Replacement
    1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: step 1, image 1 of 3 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: step 1, image 2 of 3 Razer Wolverine V3 Pro Battery Replacement, Outer Shell: step 1, image 3 of 3
      • Insert the end of a spudger or opening tool in the seam at the top of the controller.
      • Slide it around the edge to release the retaining clips.
      • Use the spudger to separate the front and back plastic outer shell of the controller.
      • Both panels should separate from the front of the bumpers.
      • This takes some patience to ensure the panels don’t crack.
      • Flip the controller so the bottom is facing up.
      • Use the spudger to separate the plastic covering on the hand grips.
      Ask FixBot
    2. Razer Wolverine V3 Pro Battery Replacement: step 2, image 1 of 2 Razer Wolverine V3 Pro Battery Replacement: step 2, image 2 of 2
      • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
      • Keep screws organized.
      Ask FixBot
    3. Razer Wolverine V3 Pro Battery Replacement: step 3, image 1 of 2 Razer Wolverine V3 Pro Battery Replacement: step 3, image 2 of 2
      • Use your hands to pry the back panel of the controller.
      • You now have access to the back buttons (2 on each side).
      Ask FixBot
    4. Razer Wolverine V3 Pro Battery Replacement: step 4, image 1 of 2 Razer Wolverine V3 Pro Battery Replacement: step 4, image 2 of 2
      • Remove the two JIS #0 scews securing the battery.
      Ask FixBot
    5. Razer Wolverine V3 Pro Battery Replacement: step 5, image 1 of 2 Razer Wolverine V3 Pro Battery Replacement: step 5, image 2 of 2
      • Lift the actuators out of the way to access the screws beneath.
      • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
      Ask FixBot
    6. Razer Wolverine V3 Pro Battery Replacement: step 6, image 1 of 1
      • Remove the face cover from the controller.
      • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
      • Now you have access to the internal components of the controller.
      Ask FixBot
    1. Razer Wolverine V3 Pro Battery Replacement, Battery: step 7, image 1 of 2 Razer Wolverine V3 Pro Battery Replacement, Battery: step 7, image 2 of 2
      • The battery is the black rectangle shown in this figure.
      • Use a JIS #0 screwdriver to remove six screws.
      • One at each corner [6 mm].
      • One in the middle of the battery [3mm].
      • One right above the battery [4 mm].
      Ask FixBot
    2. Razer Wolverine V3 Pro Battery Replacement: step 8, image 1 of 3 Razer Wolverine V3 Pro Battery Replacement: step 8, image 2 of 3 Razer Wolverine V3 Pro Battery Replacement: step 8, image 3 of 3
      • Use the spudger to gently disconnect the small circuit board on top of the battery cover.
      • Use the angled tweezers to pull the white JST connectors out of their sockets.
      Ask FixBot
    3. Razer Wolverine V3 Pro Battery Replacement: step 9, image 1 of 3 Razer Wolverine V3 Pro Battery Replacement: step 9, image 2 of 3 Razer Wolverine V3 Pro Battery Replacement: step 9, image 3 of 3
      • Remove the battery from the controller.
      • The battery is glued to the black cover.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
1 Guide Comment
Where can I get a replacement battery? Or can it be used wired with the battery removed?
wagatta1992 - Reply Share
Past 24 Hours: 8
Past 7 Days: 38
Past 30 Days: 198
All Time: 430
