Razer Wildcat Xbox One Controller Disassembly
    1. Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: step 1, image 1 of 2 Razer Wildcat Xbox One Controller Disassembly, Remove grip plates: step 1, image 2 of 2
      • Use a plastic pry tool to remove the grip plate from each side
      • The plate will release away from the back, not to the side
      Ask FixBot
    2. Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: step 2, image 1 of 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: step 2, image 2 of 3 Razer Wildcat Xbox One Controller Disassembly, Remove the back plate: step 2, image 3 of 3
      • Cut the sticker covering the center screw and remove it (PH #1)
      • Remove two screws from each grip (PH #1)
      • Use a plastic pry tool to remove rear plate from the controller
      • The three remaining screws on the back plate are PH #1
      Ask FixBot
    3. Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: step 3, image 1 of 2 Razer Wildcat Xbox One Controller Disassembly, Disassemble the board: step 3, image 2 of 2
      • Remove the M1 & M2 bumpers with two PH #1 screws (red)
      • Unplug the four rumble motors (green)
      • Unscrew the board from the controller with two PH #2 screws (blue)
      • Carefully flip the board until you can get to the ribbon cable
      • Flip the gray clip up to release the ribbon cable
      Ask FixBot
    4. Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: step 4, image 1 of 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: step 4, image 2 of 3 Razer Wildcat Xbox One Controller Disassembly, Remove the triggers: step 4, image 3 of 3
      • Remove the two PH #00 screws to remove the trigger brackets
      • Slide the trigger pin out just enough to remove it, leave the spring attached
      • The three remaining screws on each trigger are PH #1
      Ask FixBot
    5. Razer Wildcat Xbox One Controller Disassembly, Remove the bumpers: step 5, image 1 of 1
      • Remove the bumper assembly from the controller
      • The bumpers detach with two PH #1 screws
      Ask FixBot
3 other people completed this guide.
Drew
211 Reputation
1 Guide authored
3 Guide Comments
I have done everything, but how do i remove the thumbstick plastic, it would be very great if you can guide me
Daniburazz - Reply Share
I didn't remove my thumbsticks. They are likely glued on. You could try to pry them off or use heat but you are on your own for that.
Drew - Reply Share
You can´t change the thumbsticks, they are stuck and impossible to remove. I broke one of them trying to get it out. It's okay because I want to replace them with magnetic ones and I'm looking at how to do it and compatible modules.
David “Grey Wolf” - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 1,183
