Razer Tartarus V2 Scroll Wheel Replacement
  1. Razer Tartarus V2 Scroll Wheel Replacement, Razer Tartarus V2 Case Disassembly: step 1, image 1 of 2 Razer Tartarus V2 Scroll Wheel Replacement, Razer Tartarus V2 Case Disassembly: step 1, image 2 of 2
    • Turn the keypad upside down.
    Ask FixBot
  2. Razer Tartarus V2 Scroll Wheel Replacement: step 2, image 1 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 2, image 2 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 2, image 3 of 3
    • Gently peel off the rubber feet with a Jimmy.
    • Set the rubber grip pads aside so you can reapply them later.
    • Use a Phillips #0 screwdriver to remove the following screws:
    • Twelve 6.4 mm-long screws
    • Two 3.7 mm-long screws
    Ask FixBot
  3. Razer Tartarus V2 Scroll Wheel Replacement: step 3, image 1 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 3, image 2 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 3, image 3 of 3
    • Peel up the bottom left corner of the largest sticker.
    • Remove the 6.4 mm-long Phillips #0 screw.
    Ask FixBot
  4. Razer Tartarus V2 Scroll Wheel Replacement: step 4, image 1 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 4, image 2 of 3 Razer Tartarus V2 Scroll Wheel Replacement: step 4, image 3 of 3
    • Carefully lift the joystick module up and out.
    • Separate the top and bottom casing of the keypad.
    • Use an Opening tool to pry the case open along the edges if necessary.
    Ask FixBot
  5. Razer Tartarus V2 Scroll Wheel Replacement, Scroll Wheel: step 5, image 1 of 3 Razer Tartarus V2 Scroll Wheel Replacement, Scroll Wheel: step 5, image 2 of 3 Razer Tartarus V2 Scroll Wheel Replacement, Scroll Wheel: step 5, image 3 of 3
    • Remove the 5.9 mm Phillips #0 screw, that secures the daughter board and bottom casing together.
    • Lift the keycap stabilizer off from the mother board.
    Ask FixBot
  6. Razer Tartarus V2 Scroll Wheel Replacement: step 6, image 1 of 2 Razer Tartarus V2 Scroll Wheel Replacement: step 6, image 2 of 2
    • Then, remove all five of the black Phillips #0 screws holding the motherboard and bottom casing of keyboard together.
    • Two of these screws are behind or between the objects in the circles.
    • Note: All of the black internal screws are the same length as the external screws but have a smaller head.
    Ask FixBot
  7. Razer Tartarus V2 Scroll Wheel Replacement: step 7, image 1 of 1
    • Remove the bottom casing, leaving the motherboard attached to the scroll wheel and cord.
    Ask FixBot
  8. Razer Tartarus V2 Scroll Wheel Replacement: step 8, image 1 of 1
    • Gently pull the scroll wheel out of the wheel encoder (small metal part that allows the wheel to move back and forth).
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
Does anyone know where i could find a replacemnt for the flex pcb? Thank you in advance.
Mihai Roman - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 34
All Time: 479
