Razer Tartarus V2 Key Bed Replacement
  1. Razer Tartarus V2 Key Bed Replacement, Razer Tartarus V2 Case Disassembly: step 1, image 1 of 2 Razer Tartarus V2 Key Bed Replacement, Razer Tartarus V2 Case Disassembly: step 1, image 2 of 2
    • Turn the keypad upside down.
    Ask FixBot
  2. Razer Tartarus V2 Key Bed Replacement: step 2, image 1 of 3 Razer Tartarus V2 Key Bed Replacement: step 2, image 2 of 3 Razer Tartarus V2 Key Bed Replacement: step 2, image 3 of 3
    • Gently peel off the rubber feet with a Jimmy.
    • Set the rubber grip pads aside so you can reapply them later.
    • Use a Phillips #0 screwdriver to remove the following screws:
    • Twelve 6.4 mm-long screws
    • Two 3.7 mm-long screws
    Ask FixBot
  3. Razer Tartarus V2 Key Bed Replacement: step 3, image 1 of 3 Razer Tartarus V2 Key Bed Replacement: step 3, image 2 of 3 Razer Tartarus V2 Key Bed Replacement: step 3, image 3 of 3
    • Peel up the bottom left corner of the largest sticker.
    • Remove the 6.4 mm-long Phillips #0 screw.
    Ask FixBot
  4. Razer Tartarus V2 Key Bed Replacement: step 4, image 1 of 3 Razer Tartarus V2 Key Bed Replacement: step 4, image 2 of 3 Razer Tartarus V2 Key Bed Replacement: step 4, image 3 of 3
    • Carefully lift the joystick module up and out.
    • Separate the top and bottom casing of the keypad.
    • Use an Opening tool to pry the case open along the edges if necessary.
    Ask FixBot
  5. Razer Tartarus V2 Key Bed Replacement, Keys 1-19: step 5, image 1 of 1
    • To take off the keys, place the flat end of the opening tool under the edge of the key. Gently pry the key cap off of the board.
    Ask FixBot
  6. Razer Tartarus V2 Key Bed Replacement: step 6, image 1 of 3 Razer Tartarus V2 Key Bed Replacement: step 6, image 2 of 3 Razer Tartarus V2 Key Bed Replacement: step 6, image 3 of 3
    • The key stem, a small white block-like object, may be left behind. If this happens the keyboard must be opened. Once opened separate the top casing from the bottom casing and gently press the stem towards where the inside of the keyboard would be. They should pop out in this direction.
    Ask FixBot
  7. Razer Tartarus V2 Key Bed Replacement: step 7, image 1 of 2 Razer Tartarus V2 Key Bed Replacement: step 7, image 2 of 2
    • You can then place them back on the keycap by placing the end that has a small number on it back into the connector on the keycap. There is a small bump on the bottom edge of the stem, this should be facing direction of the top edge of the keycap.
    Ask FixBot
  8. Razer Tartarus V2 Key Bed Replacement, Key Bed : step 8, image 1 of 1
    • Remove the entire key bed, flip the top casing over.
    • Remove the four screws securing the key bed from the back using a Phillips #0 screwdriver.
    Ask FixBot
  9. Razer Tartarus V2 Key Bed Replacement: step 9, image 1 of 1
    • Carefully pull the key bed off.
    Ask FixBot
  10. Razer Tartarus V2 Key Bed Replacement: step 10, image 1 of 1
    • If you only want to replace the Metal Contacts, gently pop out the old metal contacts with your fingers from the key bed. Be careful not to damage the surrounding plastic.
    Ask FixBot
Derrick
572 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 404
