Razer Tartarus V2 Case Disassembly
    1. Razer Tartarus V2 Case Disassembly, Razer Tartarus V2 Case Disassembly: step 1, image 1 of 2 Razer Tartarus V2 Case Disassembly, Razer Tartarus V2 Case Disassembly: step 1, image 2 of 2
      • Turn the keypad upside down.
      Ask FixBot
    2. Razer Tartarus V2 Case Disassembly: step 2, image 1 of 3 Razer Tartarus V2 Case Disassembly: step 2, image 2 of 3 Razer Tartarus V2 Case Disassembly: step 2, image 3 of 3
      • Gently peel off the rubber feet with a Jimmy.
      • Set the rubber grip pads aside so you can reapply them later.
      • Use a Phillips #0 screwdriver to remove the following screws:
      • Twelve 6.4 mm-long screws
      • Two 3.7 mm-long screws
      Ask FixBot
    3. Razer Tartarus V2 Case Disassembly: step 3, image 1 of 3 Razer Tartarus V2 Case Disassembly: step 3, image 2 of 3 Razer Tartarus V2 Case Disassembly: step 3, image 3 of 3
      • Peel up the bottom left corner of the largest sticker.
      • Remove the 6.4 mm-long Phillips #0 screw.
      Ask FixBot
    4. Razer Tartarus V2 Case Disassembly: step 4, image 1 of 3 Razer Tartarus V2 Case Disassembly: step 4, image 2 of 3 Razer Tartarus V2 Case Disassembly: step 4, image 3 of 3
      • Carefully lift the joystick module up and out.
      • Separate the top and bottom casing of the keypad.
      • Use an Opening tool to pry the case open along the edges if necessary.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 172
All Time: 1,728
