Razer Phone Charging Port Replacement
    1. Razer Phone Charging Port Replacement, Display Assembly: step 1, image 1 of 3 Razer Phone Charging Port Replacement, Display Assembly: step 1, image 2 of 3 Razer Phone Charging Port Replacement, Display Assembly: step 1, image 3 of 3
      • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
      • Peel off the plastic speaker grill to reveal the screws.
      • Heating up the plastic grills make them easier to remove.
      • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
      Ask FixBot
    2. Razer Phone Charging Port Replacement: step 2, image 1 of 2 Razer Phone Charging Port Replacement: step 2, image 2 of 2
      • Pry the top plastic grill off with the metal spudger and reveal the screws.
      Ask FixBot
    3. Razer Phone Charging Port Replacement: step 3, image 1 of 3 Razer Phone Charging Port Replacement: step 3, image 2 of 3 Razer Phone Charging Port Replacement: step 3, image 3 of 3
      • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
      • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
      Ask FixBot
    4. Razer Phone Charging Port Replacement: step 4, image 1 of 2 Razer Phone Charging Port Replacement: step 4, image 2 of 2
      • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
      • Lift the display assembly away from the other half of the phone.
      Ask FixBot
    5. Razer Phone Charging Port Replacement: step 5, image 1 of 3 Razer Phone Charging Port Replacement: step 5, image 2 of 3 Razer Phone Charging Port Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
      • Peel back the metallic shielding over the connector using tweezers.
      • Remove the metal bracket connector.
      Ask FixBot
    6. Razer Phone Charging Port Replacement: step 6, image 1 of 2 Razer Phone Charging Port Replacement: step 6, image 2 of 2
      • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
      Ask FixBot
    1. Razer Phone Charging Port Replacement, Battery: step 7, image 1 of 3 Razer Phone Charging Port Replacement, Battery: step 7, image 2 of 3 Razer Phone Charging Port Replacement, Battery: step 7, image 3 of 3
      Buy
      • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
      • Remove the connector.
      Ask FixBot
    2. Razer Phone Charging Port Replacement: step 8, image 1 of 2 Razer Phone Charging Port Replacement: step 8, image 2 of 2
      • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
      • Grab the bracket with the tweezers and remove it.
      Ask FixBot
    3. Razer Phone Charging Port Replacement: step 9, image 1 of 3 Razer Phone Charging Port Replacement: step 9, image 2 of 3 Razer Phone Charging Port Replacement: step 9, image 3 of 3
      • Peel off and pull out the elastic tabs at the bottom of the battery.
      Ask FixBot
    4. Razer Phone Charging Port Replacement: step 10, image 1 of 2 Razer Phone Charging Port Replacement: step 10, image 2 of 2
      • Carefully use the Jimmy to wedge the battery out of the phone.
      Ask FixBot
    1. Razer Phone Charging Port Replacement, Charging Port: step 11, image 1 of 2 Razer Phone Charging Port Replacement, Charging Port: step 11, image 2 of 2
      • Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
      • There are a few gold brackets under some of the screws. Make sure to remove these and keep them for reassembly.
      Ask FixBot
    2. Razer Phone Charging Port Replacement: step 12, image 1 of 2 Razer Phone Charging Port Replacement: step 12, image 2 of 2
      Buy
      • Grab hold of the blue connector on the upper left side of the phone with the tweezers.
      Ask FixBot
    3. Razer Phone Charging Port Replacement: step 13, image 1 of 2 Razer Phone Charging Port Replacement: step 13, image 2 of 2
      • Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
      • Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
      Ask FixBot
    4. Razer Phone Charging Port Replacement: step 14, image 1 of 1
      • Using the tweezers, grab the detached charging port and ribbon.
      Ask FixBot
14 other people completed this guide.
Bryan
777 Reputation
2 Guides authored
Cal Poly, Team S19-G6, White Winter 2019 Member of Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
4 Members
60 Guides authored
10 Guide Comments
Who i can find one replacement…pls a link
Flims LP - Reply Share
Search it on Amazon.c
HolaSoy Guapo - Reply Share
hi how much you guys charge for the charging port thanks
johnny rodas - Reply Share
Does this tutorial also work for the Razer phone 2?
Derrick - Reply Share
Nah, even step one looks different for me.
Edsknife - Reply Share
Past 24 Hours: 9
Past 7 Days: 33
Past 30 Days: 118
All Time: 27,282
