Up to 20% off select tools
Razer Phone Battery Replacement
Views: 20K
View statistics:
Past 24 Hours:
9
Past 7 Days:
26
Past 30 Days:
144
All Time:
20,361
Comments: 18
13 comments on steps, 5 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your Razer Phone having problems with the battery and you need to replace it? Follow this easy guide to replacing the battery on your phone. You'll need the #000 Phillips screw driver, the Torx head T5, the tweezers, the metal spudger and the jimmy.
    1. Razer Phone Battery Replacement, Display Assembly: step 1, image 1 of 3 Razer Phone Battery Replacement, Display Assembly: step 1, image 2 of 3 Razer Phone Battery Replacement, Display Assembly: step 1, image 3 of 3
      • Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
      • Peel off the plastic speaker grill to reveal the screws.
      • Heating up the plastic grills make them easier to remove.
      • Peeling off the plastic speaker grill will ruin the adhesive used to keep it in place. A new adhesive must be used to put the grill back on the device.
      Ask FixBot
    2. Razer Phone Battery Replacement: step 2, image 1 of 2 Razer Phone Battery Replacement: step 2, image 2 of 2
      • Pry the top plastic grill off with the metal spudger and reveal the screws.
      Ask FixBot
    3. Razer Phone Battery Replacement: step 3, image 1 of 3 Razer Phone Battery Replacement: step 3, image 2 of 3 Razer Phone Battery Replacement: step 3, image 3 of 3
      • Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
      • Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
      Ask FixBot
    4. Razer Phone Battery Replacement: step 4, image 1 of 2 Razer Phone Battery Replacement: step 4, image 2 of 2
      • Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
      • Lift the display assembly away from the other half of the phone.
      Ask FixBot
    5. Razer Phone Battery Replacement: step 5, image 1 of 3 Razer Phone Battery Replacement: step 5, image 2 of 3 Razer Phone Battery Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
      • Peel back the metallic shielding over the connector using tweezers.
      • Remove the metal bracket connector.
      Ask FixBot
    6. Razer Phone Battery Replacement: step 6, image 1 of 2 Razer Phone Battery Replacement: step 6, image 2 of 2
      • Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
      Ask FixBot
    1. Razer Phone Battery Replacement, Battery: step 7, image 1 of 3 Razer Phone Battery Replacement, Battery: step 7, image 2 of 3 Razer Phone Battery Replacement, Battery: step 7, image 3 of 3
      Buy
      • Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
      • Remove the connector.
      Ask FixBot
    2. Razer Phone Battery Replacement: step 8, image 1 of 2 Razer Phone Battery Replacement: step 8, image 2 of 2
      • Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
      • Grab the bracket with the tweezers and remove it.
      Ask FixBot
    3. Razer Phone Battery Replacement: step 9, image 1 of 3 Razer Phone Battery Replacement: step 9, image 2 of 3 Razer Phone Battery Replacement: step 9, image 3 of 3
      • Peel off and pull out the elastic tabs at the bottom of the battery.
      Ask FixBot
    4. Razer Phone Battery Replacement: step 10, image 1 of 2 Razer Phone Battery Replacement: step 10, image 2 of 2
      • Carefully use the Jimmy to wedge the battery out of the phone.
      Ask FixBot
5 other people completed this guide.
Author
with
Bryan
777 Reputation
2 Guides authored
Cal Poly, Team S19-G6, White Winter 2019 Member of Cal Poly, Team S19-G6, White Winter 2019
CPSU-WHITE-W19S19G6
4 Members
60 Guides authored
5 Guide Comments
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Kraytos Barzegar - Reply Share
Where can I buy a battery and power button replacement for this phone
Kelly Sales - Reply Share
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
Ronald Winfrey - Reply Share
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
Wai-Ming Ham - Reply Share
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
Raposo morto - Reply Share
Past 24 Hours: 9
Past 7 Days: 26
Past 30 Days: 144
All Time: 20,361
