Razer Ouroboros Scroll Wheel Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
104
All Time:
5,132
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will cover how to open the Razer Ouroboros mouse, remove the existing scroll wheel, and replace it with a new one.
Note: Make sure the device is unplugged and powered off before continuing with this guide.
Parts
Tools
    1. Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to loosen the two captive screws from the bottom of the mouse.
      • Slide the palm rest out of place.
      Ask FixBot
    2. Razer Ouroboros Scroll Wheel Replacement: step 2, image 1 of 2 Razer Ouroboros Scroll Wheel Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Remove all of the stickers on the back of the mouse. After doing so, you should see six screws on the back of the mouse.
      • Use the Phillips #0 Screwdriver to remove all six of these 4mm screws.
      • Use the Phillips #00 Screwdriver to remove these two, 3mm screws.
      • Slide the side panels off of the mouse.
      • Use your tweezers to take the lock switches off of the mouse.
      • Using the T6 Torx screwdriver, remove the two bottom 4mm screws as indicated in the second picture.
      Ask FixBot
    3. Razer Ouroboros Scroll Wheel Replacement: step 3, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement: step 3, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement: step 3, image 3 of 3
      • Using the T6 Torx screwdriver, remove the two 4mm screws hidden in the deep holes indicated in the first picture.
      • Slide the top panels off of the mouse.
      • Flip the mouse over, and the mouse casing should come off.
      • There are some connectors connecting the casing to the motherboard. They should slide off. Just be careful not to break them.
      Ask FixBot
    4. Razer Ouroboros Scroll Wheel Replacement: step 4, image 1 of 3 Razer Ouroboros Scroll Wheel Replacement: step 4, image 2 of 3 Razer Ouroboros Scroll Wheel Replacement: step 4, image 3 of 3
      • Locate the 4mm screw indicated in the first picture, use a Phillips #00 Screwdriver to remove it.
      • Locate the two 4mm screws in the second picture, and remove those two with a Phillips #0 Screwdriver.
      • Now, you may remove the board that holds the scroll wheel and its components. Simply slide the wheel out and replace it.
      • Take note of the orientation in the final picture so that you can place the wheel back correctly into its mechanism.
      Ask FixBot
5 other people completed this guide.
Preston Darling
372 Reputation
2 Guides authored
1 Guide Comment
Hello, one question, did the scroll click break, is it the same procedure?
Jorge Bestani (Ayman) - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 104
All Time: 5,132
