Razer Orochi V2 Reflector Replacement
    1. Razer Orochi V2 Reflector Replacement, Battery: step 1, image 1 of 3 Razer Orochi V2 Reflector Replacement, Battery: step 1, image 2 of 3 Razer Orochi V2 Reflector Replacement, Battery: step 1, image 3 of 3
      • Remove the top shell of the mouse.
      Ask FixBot
    2. Razer Orochi V2 Reflector Replacement: step 2, image 1 of 1
      • Remove the old battery and replace it with a new battery.
      Ask FixBot
    1. Razer Orochi V2 Reflector Replacement, Baseplate: step 3, image 1 of 2 Razer Orochi V2 Reflector Replacement, Baseplate: step 3, image 2 of 2
      • Remove the four 4 mm screws that secure the top cover using a 1.5mm Hex Screwdriver.
      Ask FixBot
    2. Razer Orochi V2 Reflector Replacement: step 4, image 1 of 3 Razer Orochi V2 Reflector Replacement: step 4, image 2 of 3 Razer Orochi V2 Reflector Replacement: step 4, image 3 of 3
      • Position the plastic opening tool above the side buttons and lift to remove the top cover.
      • Use caution when pulling off the top cover as the wires are still connected.
      • Disconnect the bundled cable connector, by pulling gripping all of the wires and gently pulling, rocking side to side until the connector comes out of the socket.
      Ask FixBot
    3. Razer Orochi V2 Reflector Replacement: step 5, image 1 of 2 Razer Orochi V2 Reflector Replacement: step 5, image 2 of 2
      • Remove the three 2.5mm screws that secure the circuit board using a Phillips #000 screwdriver.
      Ask FixBot
    4. Razer Orochi V2 Reflector Replacement: step 6, image 1 of 2 Razer Orochi V2 Reflector Replacement: step 6, image 2 of 2
      • Take out the circuit board.
      Ask FixBot
    1. Razer Orochi V2 Reflector Replacement, Battery: step 7, image 1 of 3 Razer Orochi V2 Reflector Replacement, Battery: step 7, image 2 of 3 Razer Orochi V2 Reflector Replacement, Battery: step 7, image 3 of 3
      Ask FixBot
    2. Razer Orochi V2 Reflector Replacement: step 8, image 1 of 1
      Ask FixBot
    1. Razer Orochi V2 Reflector Replacement, Reflector: step 9, image 1 of 2 Razer Orochi V2 Reflector Replacement, Reflector: step 9, image 2 of 2
      • Take the reflector out of the baseplate, and replace it with a new one.
      Ask FixBot
Mateo Lindstrom
510 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 105
