Introduction
This guide will show you how to replace the mouse skates of the Razer Orochi V2. The mouse skates located in the bottom of the mouse allow smooth movement across surfaces and reduce friction. You may need to install new mouse skates if you're experiencing excessive friction, scraping, or you feel some uneven movement while using the mouse. You will not need to open the mouse at all. The only necessary tool to complete this is a plastic opening tool in order to peel the skates off. Overall this is a very easy replacement to perform, but you should be careful not to scrape the baseplate while removing the skates.
Flip the mouse over, and use a plastic opening tool to lift the mouse skates.
