Razer Naga V2 HyperSpeed Scroll Wheel Replacement
  1. Razer Naga V2 HyperSpeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 3 Razer Naga V2 HyperSpeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 3 Razer Naga V2 HyperSpeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 3 of 3
    • Take off the magnetic top and remove the dongle.
    Ask FixBot
  2. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 2, image 1 of 3 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 2, image 2 of 3 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 2, image 3 of 3
    • Heat the mouse feet with an iOpener or hairdryer.
    • Use an opening tool or pick to remove the mouse feet.
    • Reapply adhesive to the feet before reinstallation if you're reusing them.
    Ask FixBot
  3. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 3, image 1 of 1
    • Use a TR6 Torx screwdriver to remove the four screws on the underside of the mouse.
    Ask FixBot
  4. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 4, image 1 of 2 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 4, image 2 of 2
    • Flip the Razer mouse back over to the top side. Using the iFixit opening tool to slowly take the top shell off, and the right shell should fall off as well.
    Ask FixBot
  5. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 5, image 1 of 2 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 5, image 2 of 2
    • When taking the top shell off (middle shell), use precision tweezers to disconnect the battery compartment connector.
    Ask FixBot
  6. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 6, image 1 of 1
    • Disconnect the Left shell and carefully remove the white connector with tweezers.
    Ask FixBot
  7. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 7, image 1 of 1
    • Disconnect the brown ribbon cable that’s connected to the scroll wheel with precision tweezers (dull).
    Ask FixBot
  8. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 8, image 1 of 2 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 8, image 2 of 2
    • Use the iFixit Opening tool on the clip near the front of the mouse to release and remove the scroll wheel.
    Ask FixBot
  9. Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 9, image 1 of 2 Razer Naga V2 HyperSpeed Scroll Wheel Replacement: step 9, image 2 of 2
    • Widen the sides of the scroll wheel brackets that holds the scroll wheel using the iFixit Opening tool (you may need to use a little bit of force to widen the other side) and remove the scroll wheel.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 148
All Time: 858
