Razer Naga V2 HyperSpeed Motherboard Replacement
  1. Razer Naga V2 HyperSpeed Motherboard Replacement, Motherboard: step 1, image 1 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement, Motherboard: step 1, image 2 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Remove the top panel using an opening tool.
    • Remove the dongle.
    Ask FixBot
  2. Razer Naga V2 HyperSpeed Motherboard Replacement: step 2, image 1 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement: step 2, image 2 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement: step 2, image 3 of 3
    • Use an iOpener or hairdryer to heat the mouse feet.
    • Use an opening tool to remove the mouse feet.
    • Reapply adhesive onto the feet before replacement if you intend to reuse them.
    Ask FixBot
  3. Razer Naga V2 HyperSpeed Motherboard Replacement: step 3, image 1 of 1
    • Use a T6 Torx screwdriver to remove the four screws on the bottom of the mouse.
    Ask FixBot
  4. Razer Naga V2 HyperSpeed Motherboard Replacement: step 4, image 1 of 2 Razer Naga V2 HyperSpeed Motherboard Replacement: step 4, image 2 of 2
    • Use the iFixit opening tool to help remove the top middle shell, as well as the right side.
    Ask FixBot
  5. Razer Naga V2 HyperSpeed Motherboard Replacement: step 5, image 1 of 2 Razer Naga V2 HyperSpeed Motherboard Replacement: step 5, image 2 of 2
    • Disconnect the battery compartment connector.
    Ask FixBot
  6. Razer Naga V2 HyperSpeed Motherboard Replacement: step 6, image 1 of 1
    • Disconnect the ribbon cable.
    Ask FixBot
  7. Razer Naga V2 HyperSpeed Motherboard Replacement: step 7, image 1 of 1
    • Disconnect the brown wire that's connected to the scroll wheel with tweezers.
    Ask FixBot
  8. Razer Naga V2 HyperSpeed Motherboard Replacement: step 8, image 1 of 2 Razer Naga V2 HyperSpeed Motherboard Replacement: step 8, image 2 of 2
    • Use the iFixit opening tool on the clip near the front of the mouse to release the mouse from its confinement and remove it.
    Ask FixBot
  9. Razer Naga V2 HyperSpeed Motherboard Replacement: step 9, image 1 of 1
    • Remove all six Phillips #1 screws securing the motherboard.
    Ask FixBot
  10. Razer Naga V2 HyperSpeed Motherboard Replacement: step 10, image 1 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement: step 10, image 2 of 3 Razer Naga V2 HyperSpeed Motherboard Replacement: step 10, image 3 of 3
    • Remove the top left black panel first using the precision tweezers, and then carefully remove the motherboard using the precision tweezers.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 65
All Time: 314
