Razer Naga V2 HyperSpeed Battery Compartment Replacement
  1. Razer Naga V2 HyperSpeed Battery Compartment Replacement, Battery Compartment: step 1, image 1 of 3 Razer Naga V2 HyperSpeed Battery Compartment Replacement, Battery Compartment: step 1, image 2 of 3 Razer Naga V2 HyperSpeed Battery Compartment Replacement, Battery Compartment: step 1, image 3 of 3
    • Pry off the magnetic top.
    Ask FixBot
  2. Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 2, image 1 of 3 Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 2, image 2 of 3 Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 2, image 3 of 3
    • Use an iOpener or hairdryer to gently heat the mouse feet.
    • Use an opening pick or opening tool to remove the mouse feet.
    • If you intend to reuse the mouse feet, you may need to reapply adhesive.
    Ask FixBot
  3. Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 3, image 1 of 1
    • Use a TR6 Torx screwdriver set to remove the four screws on the underside.
    Ask FixBot
  4. Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 4, image 1 of 2 Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 4, image 2 of 2
    • Flip the mouse back over.
    • Use an opening tool to slowly take the top shell off, and the right shell should fall off as well.
    Ask FixBot
  5. Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 5, image 1 of 2 Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 5, image 2 of 2
    • When taking the top shell off (middle shell), use precision tweezers to disconnect the battery connector.
    Ask FixBot
  6. Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 6, image 1 of 2 Razer Naga V2 HyperSpeed Battery Compartment Replacement: step 6, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery compartment.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 99
All Time: 550
